Silver eagle, fiberglass siding. Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » June 2007 » Silver eagle, fiberglass siding. « Previous Next »
John Harrelson (Jharl)
Username: Jharl
Post Number: 51
Posted From: 72.73.67.180
Posted on Friday, June 22, 2007 - 8:25 pm:
Hi all yet again, the guy I bought my bus from redid the inside and put in new windows, and took off the fiberglass siding I thing to install the windows. I have made a vane attempt to seal the siding back up using sealant and metal strips I had made up to get the bus back ease from California.
the question i have is how does one reapply fiberglass siding to the bus and kee mother nature out.
jack
Post Number: 41
Posted From: 76.4.142.242
Posted on Saturday, June 23, 2007 - 10:37 am:
john; I don't know as to what extent you need re- secured but they have an epoxy that you put on the surface and hold in place for a while and you will not get it loose ever again. the metal that i saw it used on actually tore and never broke the epoxy loose. It is available at a paint and body shop supplier.
Username: Davidanderson
Post Number: 205
Posted From: 69.153.52.58
Posted on Saturday, June 23, 2007 - 5:34 pm:
Jack,
I used urethane caulk. Trade name NP-1 made by Savogran. Also, Sikaflex will work. These products will flex with road movement. 7 years now and no problems.
David
