Glenn Williams (Glenn)
Post Number: 44 Registered: 6-2006 Posted From: 216.163.57.32
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, July 04, 2007 - 8:49 pm: | |
I am stipping the paint off of my 4905 bumper and I found this weird green stuff on the bumper. It is an applied substance, Zip Strip doesn't touch it, heat doesn't touch it. What is it and how do I make it go away? It looks like the remains of old plastic wrap for shelf storage, assuming the bumper has been replaced at some point. On a side note - what pixel Length by Width is proper for posting pictures? |
Post Number: 41 Registered: 5-2007 Posted From: 71.16.224.115
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, July 04, 2007 - 9:19 pm: | |
150x150 |
Post Number: 432 Registered: 7-2006 Posted From: 66.217.107.180
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, July 04, 2007 - 9:37 pm: | |
Try "Purple Power" cleaner on a small inconspicuous spot. That stuff is great for removing a layer of anything off anything.. But... it can also remove the original paint.... Plain dish detergent and sugar (1/2 + 1/2) is safe and works better than commercial hand cleaners, and will also take glue, tar, etc., off painted surfaces.... |
Douglas Wotring (Tekebird)
Post Number: 216 Registered: 10-2004 Posted From: 71.230.23.231
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, July 05, 2007 - 10:29 am: | |
hmm painted bumper......I suspect the "gree stuff" is Zinc Chromate Primer. very hard to get off |
Post Number: 45 Registered: 6-2006 Posted From: 216.163.57.32
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, July 05, 2007 - 11:47 am: | |
Hey Doug, I wish this was Zinc chromate! I found that on the aluminum panel below the windshield and it comes off allright. I have a new computer that is making it harder to shrink a picture to 30k. My resoloution is still too high. Has anyone ever recieved a part that was factory wrapped for storage? I suspect it is like the army's cosmoline (SP?). |
Post Number: 46 Registered: 6-2006 Posted From: 216.163.57.32
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, July 05, 2007 - 11:52 am: | |
Here is a picture |
Post Number: 1939 Registered: 1-2001 Posted From: 75.108.74.232
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, July 05, 2007 - 12:58 pm: | |
Genn, have you tried a little heat from a propane torch. It might flash right off. Should be able to do easily without damaging the chrome. Richard |
Post Number: 165 Registered: 7-2006 Posted From: 4.240.214.217
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, July 05, 2007 - 8:36 pm: | |
Are you SURE it is not the chrome that is missing? Mine looked similar to that in a couple of places and over time that is what has come forth. FWIW RCB |
John Lacey (Junkman42)
Post Number: 11 Registered: 3-2007 Posted From: 204.49.140.153
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, July 05, 2007 - 11:33 pm: | |
Is it possible that the green stuff came from roswell? Be careful it might start growing and cover Your bus. John |
Post Number: 796 Registered: 5-2005 Posted From: 68.242.197.123
Rating:  Votes: 1 (Vote!) | Posted on Friday, July 06, 2007 - 10:30 pm: | |
The bumper may have been electrocoated with zinc chromate or copper before being chromed. That was normal in the early days of plating large items. It filled the natural grains of the raw metals. Abrasive blast and have the bumper completely chromed again or abrasive blast, prime and paint with imron or expoxy paints. You will need to blast the chrome plating off and clean up the metal before painting. Use Garnet abrasive to cut the chrome... |
Post Number: 169 Registered: 7-2006 Posted From: 4.240.213.110
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, July 06, 2007 - 11:50 pm: | |
DrDave...isn't that the way all re-chroming is done anyway?....blasting first? I feel you are dead on on your post. Thanx for the wisdom. RCB |
Post Number: 435 Registered: 7-2006 Posted From: 66.217.107.150
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, July 07, 2007 - 12:55 am: | |
Re: "Is it possible that the green stuff came from Roswell?" Oh sure.....Blame the "illegal aliens"... |
Post Number: 797 Registered: 5-2005 Posted From: 70.10.160.165
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, July 07, 2007 - 8:06 am: | |
Roswell Aliens were not "illegal" They were from Roswell.... Haahaaaaahheeeee..... |
John Jewett (Jayjay)
Registered Member Username: Jayjay
Post Number: 373 Registered: 1-2001 Posted From: 70.242.226.50
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, July 07, 2007 - 12:10 pm: | |
Chrome is removed for replating the same way it is applied, via electrolysis. Then you copper plate the piece and apply new chrome. You can't plate over zinc chromate or any other paint process. The high demand of Chinese chrome shops is the reason copper is so high in price. Cheers...JJ |
Post Number: 621 Registered: 10-2003 Posted From: 71.58.117.21
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, July 09, 2007 - 5:19 pm: | |
Sure.....blame it on the Chineese- |
Post Number: 171 Registered: 7-2006 Posted From: 4.240.237.236
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, July 09, 2007 - 11:24 pm: | |
JJ...I had always thought that (what you wrote) but someone told me I was mistaken that sand blasting was the way to go and infact, led me to believe that it was all done that way. ....... Thanx for the confirmation. Anyone got a good chrome shop that doesn;t charge an arm and a leg?....El Paso ( we are in Las Cruces) quoted nearly $700 for the front bumpers and guards alone....not including the rear. RCB |
Post Number: 47 Registered: 6-2006 Posted From: 216.163.57.32
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, July 10, 2007 - 12:14 pm: | |
Thanks for all of the responses! I was gone over the weekend and didn't catch up on these posts. This bumper is not chromed and never was. It is a GMC 4905 bumper and is aluminum with the standard (clear?) anodizing. The andodizing in the exposed areas is in excellent condition. I like the roswell idea though. |
James Smith (Tomcat)
Registered Member Username: Tomcat
Post Number: 42 Registered: 8-2005 Posted From: 207.200.116.13
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, July 10, 2007 - 12:50 pm: | |
Hey RC, I'm wondering if that $700 figure would drop by 50% if you did most of the polishing yourself? Jay 87 SaftLiner |
Post Number: 172 Registered: 7-2006 Posted From: 4.240.214.224
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, July 10, 2007 - 2:56 pm: | |
Good question. Just seemed like an enormous amount to me...and apparently to another shop in AZ and one in Albuquerque...though I did not get a quote from either of them. RCB |
