Henry 96A3 (Hank)
Registered Member Username: Hank
Post Number: 106 Registered: 11-2005 Posted From: 69.129.126.133
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, July 09, 2007 - 6:25 pm: | |
I just got done installing new front radius rod bushings on my 96A3. They are the non sleeved variety. MCI has a tool you're supposed to use to install the bushings but I figured out an easy way that requires no special tools and thought I'd pass it along. Get a bottle of isopropyl alcohol (rubbing alcohol) and slather some on the OD of the bushing and the hole it seats into. Pound the bushing into place with a soft mallet. It works like a charm and the alcohol wont damage the rubber bushing. The alcohol will help you slide the rods onto the posts too. Hank |
