Bad Fuel Update Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » July 2007 » Bad Fuel Update « Previous Next »
Dennis Tracy (Eagle10)
Username: Eagle10
Post Number: 16
Posted From: 74.75.127.129
Posted on Wednesday, July 18, 2007 - 8:35 am:
About a month ago, I thought I had a bad fuel issue but it turned out to be something different. I lost power going down the road so I changed fuel filters and it went fine. I also treated the fuel at that time. The next time I tried to start it, it would'nt start and it ended up being the fuel shut off. It was sticking off and sometimes part way off. I pulled my bed and put WD 40 on the pivot point. I worked it about 300 times and now it springs back great. Enjoy the good life.
Username: Dreamscape
Post Number: 47
Posted From: 64.40.223.242
Posted on Wednesday, July 18, 2007 - 10:18 am:
Great news. Nice to hear of problems that get fixed and the results.
Austin Scott Davis (Zimtok)
Username: Zimtok
Post Number: 157
Posted From: 216.37.73.226
Posted on Wednesday, July 18, 2007 - 11:03 am:
Great to hear you found the problem.
I'm beginning to believe that I will always be chasing down little gremlins with my bus. Nothing big just little annoying things.
Just the other day my flashers started flashing irregularly. I thought probably bad ground, turned out to be a bulb. The one filament had burned out and then shorted to the other filament. Grounding through the other filament caused it to flash irregularly.
(Message edited by zimtok on July 18, 2007)
J.C.B. (Eagle)
Username: Eagle
Post Number: 124
Posted From: 209.183.34.48
Posted on Wednesday, July 18, 2007 - 5:04 pm:
I would suggest that you lubricate that with something like slick 50 or marvel oil as WD40 is not a very good lubricant.
Username: Justin25taylor
Post Number: 26
Posted From: 74.193.73.245
Posted on Saturday, July 21, 2007 - 3:05 pm:
J.C.B is right. WD40 will gum up after a while and could make it stick worse than before. WD40 was not intended to be a lubricant. It was meant to displace water and maybe to provide some instant temporary lubrication.
Marvel, or 3 in 1 oil would be my choice. plain 30wND motor oil does good too.
