Ed Brenner (Epbrenner)
Registered Member Username: Epbrenner
Post Number: 4 Registered: 5-2007 Posted From: 205.188.117.73
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 02, 2007 - 7:34 pm: | |
On an mci 5 24 volt system does someone make a voltage reducer for the 12 volt system on the tow vehicle so you can have your cars light system function with the bus ? |
Larry & Lynne Dixon (Larry_d)
Post Number: 101 Registered: 7-2005 Posted From: 71.117.202.171
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 02, 2007 - 8:45 pm: | |
Ed I think any auto parts or even W-Mart, my 4905 has 24 and the little unit on the bus and goes down to the plugin. 4905 larry |
Post Number: 456 Registered: 7-2006 Posted From: 66.217.101.188
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 02, 2007 - 9:10 pm: | |
Ed - They sell kits like this *BX8869 Bulb and Socket Tail Light Wiring Kit* at Walmart, AutoZone, and all camping stores. Fit it with 24v bulbs of the correct type, and away you go! |
Sean Welsh (Sean)
Post Number: 627 Registered: 1-2003 Posted From: 71.108.2.133
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 02, 2007 - 9:21 pm: | |
All it takes is a handful of 24v automotive-type relays, available at Grainger, McMaster-Carr, Allied, or Newark. Here's a circuit diagram: http://odyssey.smugmug.com/gallery/131040#4750590-O-LB You should be able to put this together for under $20. -Sean http://OurOdyssey.BlogSpot.com |
Hans (Buellhans)
Registered Member Username: Buellhans
Post Number: 61 Registered: 2-2007 Posted From: 199.60.181.9
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 02, 2007 - 10:59 pm: | |
Say did you figure out your smoke problem , |
Hans (Buellhans)
Post Number: 65 Registered: 2-2007 Posted From: 199.60.181.9
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 03, 2007 - 2:09 am: | |
Oh Sean did you figure out the smoke problem? |
Gary Tilden (Garysrzi)
Registered Member Username: Garysrzi
Post Number: 1 Registered: 7-2007 Posted From: 70.176.241.12
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 03, 2007 - 3:00 am: | |
24 volt to 12 volt Any electronics store, not radio shack, has a 24volt to 12volt resister. less than a buck. 3 prongs, 24 volt in, ground, 12 volts out. stick any where you wish to reduce voltage. I added led marker lights, just took off of any 24 volt light. |
Ed Jewett (Kristinsgrandpa)
Post Number: 333 Registered: 2-2003 Posted From: 64.24.214.25
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 03, 2007 - 12:02 pm: | |
I did the same thing Gary did. Radio Shack voltage regulator, they didn't have them at the local store so I ordered off the internet. I wanted them for the LED marker lights also. One was enough to handle the load but I paralled two of them for safety in case one burns out the lights will continue to work. They have a fairly small amperage rating so check your load and remember, paralleling two of them doubles your amperage rating. Ed |
Leland Bradley (Lee_bradley)
Registered Member Username: Lee_bradley
Post Number: 14 Registered: 11-2006 Posted From: 138.163.0.46
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 03, 2007 - 1:14 pm: | |
Hans, Check Sean's blog; he is in the middle of an in-frame. |
Arnie Molloy (Ayjay)
Post Number: 79 Registered: 10-2005 Posted From: 68.160.156.113
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, August 05, 2007 - 2:06 pm: | |
Hi: If your 24 volt system is made up of 2 or more 12 volt batteries, simply tie into the connection between the batteries to pull off your 12 volts. That's how the RTS runs all their lighting on 12 volts. AyJay |
