Doug Ritter (Texrbama)
Registered Member Username: Texrbama
Post Number: 26 Registered: 3-2007 Posted From: 68.246.225.32
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 09, 2007 - 7:53 pm: | |
One more question before we head out this weekend. Any suggestions on a electrical fuel pump for a 7.5/3 cylinder yanmar generator. I want to insall an electrical 12 v. pump but not sure about the psi rating or type. Standing by... |
Post Number: 153 Registered: 8-2004 Posted From: 12.77.62.200
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 09, 2007 - 9:39 pm: | |
__. Do you mean a proper pressure-providing fuel pump or just a "lift pump" to assure that there will be enough fuel supplied to the generator? |
Post Number: 30 Registered: 4-2007 Posted From: 74.193.73.245
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 09, 2007 - 11:04 pm: | |
Holley and a bunch of other company's make pumps for just that. I wouldnt go over about 5-6 psi. You dont want to force fuel to the injector pump, just "provide" fuel to it. You might also want to install an in line filter before the electric pump to keep big hunks of stuff out. You are going to make your injector pump live a long healthy life by not making it draw fuel all the way from the tank. Good luck, Justin |
Post Number: 713 Registered: 10-2003 Posted From: 71.58.117.21
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 10, 2007 - 8:29 pm: | |
Napa lists fuel pumps with lower pressure that may suit your needs. Just look at the specs in their book. |
Registered Member Username: Cgoodwin
Post Number: 111 Registered: 10-2005 Posted From: 71.212.78.253
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, August 11, 2007 - 11:31 pm: | |
I do a lot of work with lift pumps and can not stress enough that you need to know the delivery rate of the original pump or the supply requirements of the IP being supplied. IF the pressure is to low you will loose power or starve the IP is it has an internal pump and possible death of the iP due to cavitation is a possibility. If you exceed the supply pressure you can loose a seal or loose control of the fuel delivery. Call Yanmar and ask what pressure your IP requires. |
Post Number: 27 Registered: 3-2007 Posted From: 206.138.130.3
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, August 13, 2007 - 2:28 pm: | |
I spoke with the dealer/tech. for Yanmar. 4-6 psi not to exceed 10 psi. Another minor issue off the books. Thanks guys. |
