Chris (Thequagmireman)
Registered Member Username: Thequagmireman
Post Number: 1 Registered: 8-2007 Posted From: 75.49.6.63
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 17, 2007 - 12:02 pm: | |
Wow for so long i tired to register on here and it finally worked!!! First Question: What oil filter would be used on a 1967 PD-4107? Spin on or cartrage? 2: What type of oil is acceptable to use in the 4 speed manual Spicer tranny? 3: ...... I guess i should make seperate threads for seperate topics |
Post Number: 1278 Registered: 12-2000 Posted From: 67.181.189.94
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 17, 2007 - 12:17 pm: | |
Chris - Welcome aboard! Not sure of the filter numbers, they're in the bus. But you can use the same oil in the tranny that you use in the engine (CF-2, Straight 40wt, 1% or less sulfated ash content), altho some busnuts have used single weight synthetic with good results. What's the VIN on your 4107? FWIW & HTH. . .
![:-)](http://www.busnut.com/bbs/clipart/happy.gif) |
Post Number: 2 Registered: 8-2007 Posted From: 75.49.6.63
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 17, 2007 - 12:31 pm: | |
The bus is an hour away and the place that has the filters is the opposite direction from where I am now :-( I can let you know my VIN this weekend Whats FWIW and HTH ? |
Post Number: 720 Registered: 10-2003 Posted From: 71.58.117.21
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 17, 2007 - 5:09 pm: | |
Unless an adapter has been added, it should have a cartridge-#6437275 should be the part number. Any NAPA can get it by crossing over the number, or any large auto parts store for that matter. |
Post Number: 7 Registered: 8-2007 Posted From: 12.75.84.66
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 17, 2007 - 5:32 pm: | |
My VIN is 4107-671 Thanks John! |
dutch (Dutch)
Registered Member Username: Dutch
Post Number: 112 Registered: 2-2007 Posted From: 66.68.98.151
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 17, 2007 - 9:07 pm: | |
fwiw :For What It's Worth hth: Hope This Helps (or is it that helps??) |
