Mister question Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » August 2007 » Mister question « Previous Next »
Username: Timb
Post Number: 61
Posted From: 66.165.176.60
Posted on Friday, August 31, 2007 - 12:06 pm:
Last night I was contemplating the systems needed for a new conversion and while drawing out the plumbing an idea ran through my mind. Could grey water be used for a radiator mister system? If so it would seem to provide a way to reduce grey water and also not impact your potable supply. Any thoughts....question my sanity etc?
Username: Dreamscape
Post Number: 109
Posted From: 166.129.27.232
Posted on Friday, August 31, 2007 - 12:10 pm:
Gray water probably would have soap residue in it. Then you would be blowing bubbles as you travel down the road.
I personaly think there would be too much "stuff" in the water and plugging the nozzles.
Don't really know for sure, never tried it.
FWIW
Paul
(Message edited by dreamscape on August 31, 2007)
Username: Drivingmisslazy
Post Number: 1979
Posted From: 75.108.79.214
Posted on Friday, August 31, 2007 - 1:04 pm:
A properly designed mister system will use so little water that you would never miss it.
Richard
Username: Timb
Post Number: 62
Posted on Friday, August 31, 2007 - 2:46 pm:
Thanks for the responses I figured there was a reason I hadn't heard of anyone doing it :-)
Username: Kyle4501
Post Number: 369
Posted From: 65.23.106.193
Posted on Friday, August 31, 2007 - 3:53 pm:
The stuff that doesn't evaporate will stay on the radiator fins. If not cleaned off, could build up & reduce efficiency.
Would be easiest to use distilled water - No dried residue to mess with :-)
