Proheat X45 Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » December 2007 » Proheat X45 « Previous Next »
Username: Dreamscape
Post Number: 150
Posted From: 64.40.222.139
Posted on Thursday, October 18, 2007 - 7:29 pm:
Does anyone have experience installing a Proheat X45? I have downloaded all of the instructions from the net, looking for personal experiences, thoughts etc..
Thanks,
Paul
Greg Roberts (Eagle 20) (Gregeagle20)
Username: Gregeagle20
Post Number: 220
Posted From: 76.248.96.70
Posted on Friday, October 19, 2007 - 3:14 pm:
I had one in a motor yacht and it was a great unit that used very little battery power. I only had one problem with the unit in the years I used it and that was a failed bushing on the atomizing air blower. The unit self diagnosed the problem and I ordered a blower and installed it in about an hour. I bought a used take out unit for my Eagle and I will install it in the next month or so. Since I live down in deep south Texas I have not been in a hurry to install it. Good luck! - Greg
Post Number: 151
Posted on Friday, October 19, 2007 - 3:59 pm:
Greg,
I live in Hawley, just north of Abilene. I'm not in a big hurry either to install mine. I got my used take out from the e place the other day. I just thought I would think ahead on the installation and ask questions. Right now I'm dealing with RUST and removed the front windshields. Not a pretty site. Let me know how your install goes and how you did it please.
Good Luck to You also,
Paul
George Myers (George_myers)
Username: George_myers
Post Number: 3
Posted From: 67.72.98.92
Posted on Saturday, October 20, 2007 - 9:09 pm:
If you install the radiators near the furnace with short tubing runs, the installation should be easy. I installed a Webasto in the very rear of my coach and have long runs to the front for the radiators. The circulating pump that came with the unit would not move enough water to keep the internal temperature of the furnace within specifications, and it shut down. Getting everything figured out and functioning was the worst job so far that I have done on any coach. I wrote up my trials and tribulations in "Bus Conversions Magazine" in the Jan, Mar, Apr, and June 2003 issues. The same information with additional details can be found in my book "Plumbing Systems for Coach Conversions
Post Number: 153
Posted From: 209.183.32.44
Posted on Monday, October 22, 2007 - 9:20 pm:
George,
Thanks for the information. I will look up those issues when I return home in a couple of weeks. For now I had thought about hooking into the coolant lines in the bay in front of the fuel tank. (Model 01 with four bay doors.) I think that is close to center. I will have to measure the runs from the front exchanger (by driver and co-pilot) to the bedroom in the rear and see how close it is.
You make a very good point.
Thanks, Paul
Don Evans (Doninwa)
Username: Doninwa
Post Number: 84
Posted From: 66.45.165.58
Posted on Tuesday, October 23, 2007 - 12:04 am:
Paul,
Are you planning separate circuits for each zone or one loop for cabin heat? I was planning separate circuits until it was suggested that a much simpler way was to run one loop and control the fans in the heaters with thermostats.
If one loop does it really matter much where in the loop you put the pump/boiler?
I am putting the Proheat in the rear bay to be close to engine preheat loop and the main hot water and heating loop. I will use the engine preheat and hot water a lot more than cabin heat, at least I hope it tends to be warm where ever we land for most nights. :-)
Don 4107
Username: George_mc6
Post Number: 275
Posted From: 76.168.69.233
Posted on Tuesday, October 23, 2007 - 12:24 am:
I'm not trying to be a wise ___, just injecting a thought. Myers' runs weren't too long, his pipe was too small! And/or the radius on his elbows was too short! ?
Todd
Username: Joemc7ab
Post Number: 149
Posted From: 66.38.159.33
Posted on Tuesday, October 23, 2007 - 12:48 am:
And it was run in series.
Joe.
Username: Joemc7ab
Post Number: 150
Posted on Tuesday, October 23, 2007 - 12:11 pm:
Accessability was another problem that George Meyers had. If any changes are needed or wanted, that is one factor to keep in mind. There was a poster here a while back that used the information available on the Weil-Mclean website with good results. A bus is like a house, except smaller. A while back I bought a copy of the Hydronic Systems design manual, which was produced for the Canadian Hydronics Counsel by teca (Thermal environmental comfort association). Similar info is available on the net, but you have to dig for it.
Joe.
Post Number: 5
Posted From: 67.72.98.85
Posted on Tuesday, October 23, 2007 - 2:25 pm:
Yes, my 3/4 ID line was too small for the length of the series runs. However, there is also a lot of narrow tubing, with many turns, in the radiators and heat exchangers. If I were doing it again, I would put them in parallel off big manifolds near the furnace.
George Myers
Post Number: 154
Posted From: 166.129.96.135
Posted on Friday, October 26, 2007 - 11:48 pm:
Don and others,
I was planning to run one line and T off from that. Now George has brought up an idea of a manifold. I will have to do more research as I can see the need to keep them somewhat seperated so that the heat is more evenly distributed.
Paul
Post Number: 191
Posted on Saturday, December 08, 2007 - 7:38 am:
Where is the best location to install it, bays or where the old A/C compressor was next to the engine? My bays are getting full and I am concerned with with air intake for the burner. Is my thinking correct? If not please straighten me out. Thanks
