Battery voltage question? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » October 2007 » Battery voltage question? « Previous Next »
John Harrelson (Jharl)
Username: Jharl
Post Number: 82
Posted From: 65.175.244.220
Posted on Thursday, October 25, 2007 - 10:44 am:
I have several 12 volt batteries installed in parallel for house power; I am looking to replace them soon. I will be going to some version of 6 volt deep cycle battery. Please note that in this example it is a perfect world like on TV in the town of perfect. My question is what happens to the amp hours if the batteries are connected in parallel for 12 volt verses batteries tied in series parallel? In my example I will say that there are 5 group 28 12 volts at 100 amp hours that equals 500 amp hours. In a separate bus there are 4 6 volt batteries at 200 amp hours each which is 800 amp hours tied in series parallel to make 2 12 volt cells. Is this correct or does the to cells equal 400 amp hours?
Jack
I love my ugly bus
jharl
Jerry W Campbell (Jerry_w_campbell)
Username: Jerry_w_campbell
Post Number: 13
Posted From: 69.19.14.17
Posted on Thursday, October 25, 2007 - 11:41 am:
Hi John,
With the 6 volt setup you would have 400 amps at 12 volts. In series the voltage doubles and the amps are divided in half.
Good Luck
Jerry
Edward J. Sommers (Sommersed)
Username: Sommersed
Post Number: 26
Posted From: 148.78.155.174
Posted on Thursday, October 25, 2007 - 11:50 am:
400 is correct.
Voltage/amp hours are accumulative in one discipline only, depending on if they are wired series, or parallel.
I like to use the example of this using a 10 battery array. If you wire 10, 12 volt, 100 amp hour batts in series you end up with 120 volts but with only 100 amp hours.
Wire the same 10 batts parallel and you end up with the 12 volts but at 1000 amp hours.
Ed
Username: Jharl
Post Number: 83
Posted on Thursday, October 25, 2007 - 12:30 pm:
wow i know something. But I was not sure. Thanks guys that will help me decide about what do put in. taking suggesttions
