John Harrelson (Jharl)
Registered Member Username: Jharl
Post Number: 86 Registered: 7-2005 Posted From: 72.73.127.231
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, November 04, 2007 - 6:32 pm: | |
I have been noticing that some things on the bus a comming loose. I was told that i could titen them all up if I tighen the bus bolt. any clue as to where this is. jack (leaving self wide open) |
John Lacey (Junkman42)
Post Number: 19 Registered: 3-2007 Posted From: 204.49.140.154
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, November 04, 2007 - 7:31 pm: | |
The bus bolt will be located right behind the muffler bearing. Be sure to clean the muffler bearing with a bucket of prop wash before working with the bus bolt. If the rules are not followed the framus valve will implode. John |
Glenn Williams (Glenn)
Post Number: 102 Registered: 6-2006 Posted From: 216.163.57.212
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, November 04, 2007 - 8:06 pm: | |
I'ts actually best to coat the framus valve with 20wt blinker fluid to prevent implosion before using the highly corrosive (and addictive to hampsters) prop wash. |
Jim Rink (Fakeguy)
Post Number: 67 Registered: 1-2005 Posted From: 24.33.84.95
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, November 04, 2007 - 8:16 pm: | |
NEVER TOUCH YOUR BUS BOLT unless you have first changed the air in ALL your tires...stale and depressurized tire air has been blamed for the majority of inverter root canal failures |
Post Number: 116 Registered: 3-2007 Posted From: 76.4.149.200
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, November 04, 2007 - 8:28 pm: | |
you guys are all wrong about where the bus bolt is. ALWAYS LOOK FIRST BEHIND THE WHEEL 99.9% it is then only loose bolt on the entire coach. |
Post Number: 1100 Registered: 12-2000 Posted From: 76.68.121.96
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, November 04, 2007 - 8:38 pm: | |
Also, in rare circumstances, the oxygen/nitrogen mix in the atmosphere of the rear third of the coach may negatively impact your efforts. Further contamination by carbons monoxide and dioxide will decrease effciency. Best combatted by breathing deeply, enter the area and hold your breath throughout the procedure. Bus bolts are not to be taken lightly. happy coaching! buswarrior |
Post Number: 528 Registered: 11-2005 Posted From: 63.97.117.30
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, November 04, 2007 - 8:56 pm: | |
It appears to me that this bolt has caused a bunch of loose nuts. |
Post Number: 409 Registered: 1-2005 Posted From: 208.118.13.34
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, November 04, 2007 - 8:59 pm: | |
What you REALLY needed to do is tighten the bus NUT (Message edited by pete RTS/Daytona on November 04, 2007) |
JR Lynch (Njt5047)
Post Number: 192 Registered: 7-2006 Posted From: 69.132.233.230
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, November 04, 2007 - 9:30 pm: | |
Since I've got an MCI, and only EAGLEs have bus BOLTS...and my nuts are pretty tight. I think...? Does that mean my only problems would be related to my muffler bearing? BTW, how much does an MCI muffler bearing cost? JR |
Post Number: 540 Registered: 7-2006 Posted From: 66.217.102.56
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, November 04, 2007 - 9:44 pm: | |
Re: "Since I've got an MCI, and only EAGLEs have bus BOLTS...and my nuts are pretty tight. " I heard that Prevost owners have the tightest nuts of all! |
Post Number: 694 Registered: 10-2004 Posted From: 70.220.53.94
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, November 04, 2007 - 10:41 pm: | |
Hmmm, I happen to own one but... |
james dean boggs (Jd_boggs)
Post Number: 121 Registered: 11-2004 Posted From: 71.146.79.132
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, November 04, 2007 - 11:17 pm: | |
I have neither an MCI nor an Eagle. What's guy to do? You guys kill me sometimes! |
Bob Ayers (Califbob)
Registered Member Username: Califbob
Post Number: 45 Registered: 8-2006 Posted From: 4.246.230.78
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, November 04, 2007 - 11:59 pm: | |
Bus bolt? I belive in is aligned with the cretisfran. I recall on my 04 it never came lose because I used the spesamyfilia. |
Hans (Buellhans)
Registered Member Username: Buellhans
Post Number: 90 Registered: 2-2007 Posted From: 70.71.249.75
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 05, 2007 - 1:04 am: | |
personally I think the nut behind the wheel is lose . Weekend pass ? Or do you wear a hockey helmet when you are in the bus? |
Ken Turner (Pipesusmc)
Registered Member Username: Pipesusmc
Post Number: 81 Registered: 9-2002 Posted From: 71.113.39.174
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 05, 2007 - 1:43 am: | |
I know that guy!!!! He has a face like a wrench, everytime I look at him my nuts tighten up! |
Registered Member Username: Chucks
Post Number: 1144 Registered: 10-2003 Posted From: 68.240.90.104
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 05, 2007 - 6:58 pm: | |
Hey, I found it!!! It's part number 27 in Figure 4-32 on page 4-26 of the MC9 Maintenance Manual. All it says is "Bolt", so that MUST be the one you're looking for!!! You can send my consulting check to Livingston, TX. I'll be waiting! LOL PS: Ooops, I just noticed you have an Eagle. Well, there's LOTS of bolts, but you can't tighten them, they're all rusted solid. Maybe you should leave well enough alone? Hah! |
Hans (Buellhans)
Post Number: 92 Registered: 2-2007 Posted From: 199.60.189.9
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 06, 2007 - 12:05 am: | |
Oh sorry its a bucket of bolts your driving thats different |
Don Evans (Doninwa)
Post Number: 87 Registered: 1-2007 Posted From: 66.45.165.58
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 06, 2007 - 11:41 am: | |
I think I see why there are so many loose nuts here. Y'all been turning them the wrong way, everybody knows Bus Bolts are left hand thread! Don 4107 PS: My rivets are just fine thank you very much. |
Post Number: 209 Registered: 2-2001 Posted From: 69.77.146.206
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 06, 2007 - 2:12 pm: | |
This thread has me thinking that a bunch of the above contributing fasteners have been getting tight a little too often! Jim-Bob |
Post Number: 1101 Registered: 12-2000 Posted From: 76.66.17.103
Rating:  Votes: 1 (Vote!) | Posted on Tuesday, November 06, 2007 - 4:53 pm: | |
Oh yeah.. Thanks for reminding me Jim. A healthy slug of Molson Canadian for both the bus bolt and the bus nut should make the whole process go a lot smoother. It may require more than one application... happy coaching! buwarrior |
Post Number: 1314 Registered: 12-2000 Posted From: 67.181.166.160
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, November 06, 2007 - 10:45 pm: | |
Buswarrior - And I'll lift a Guinness Stout to your Molson - together we shall. . . we shall. . . we shall. . . What was it we were trying to do? Darned multiple applications, anyway. . . FWIW & HTH,
Post Number: 1106 Registered: 12-2000 Posted From: 76.66.19.38
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, November 07, 2007 - 5:03 pm: | |
create and solve, all of life's little problems? happy coaching! buswarrior |
