Jim Schrecengost (Schrec)
Registered Member Username: Schrec
Post Number: 56 Registered: 2-2007 Posted From: 24.2.127.94
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, January 11, 2008 - 9:54 pm: | |
I am going to be installing 2 roof mount A/C units in my 4106.....but not right away. (not enough money) However if I install the standered 14 inch roof vent can I go back and install the A/C in the same opening. I want to finish off the inside ceiling and I figured as long as I wire it for the A/C it would work. Does anyone see anything I am not. Thanks Schrec |
JR Lynch (Njt5047)
Post Number: 204 Registered: 7-2006 Posted From: 69.132.233.230
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, January 11, 2008 - 10:58 pm: | |
A standard RV roof vent (14 X 14)will accomodate RV rooftop ACs. Just be sure that ALL the wiring necessary to operate the unit is in place. Some units (Dometic HP for one) require 12Vdc and thermostat wiring in addition to the 120Vac supply. As long as the wiring is in place, you'll be all set to finish off the ceiling and install the ACs whenever you wish. Another thing...if you use thermostats with "phone" looking cabling...that ain't phone cables. Most thermostats use Cat 5 cabling. Be sure of the wiring requirements of the AC you plan to use. JR (Message edited by njt5047 on January 11, 2008) |
Post Number: 814 Registered: 10-2003 Posted From: 71.58.48.5
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, January 11, 2008 - 11:40 pm: | |
You could check the manufacturer of the AC.s you intend to use. They may have intallation instructions online. |
Randy Davidson (Rdavidson)
Registered Member Username: Rdavidson
Post Number: 6 Registered: 7-2006 Posted From: 69.19.14.39
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, January 11, 2008 - 11:43 pm: | |
I've posted this before but it is worth repeating now. A standard 14x14 is just a nominal size for reference. The actual AC unit will require, in my case for Durotherm, a 14.25 x 14.25 minumum opening. Be very careful about this. I was too literal and made them EXACTLY 14x14 -- big mistake. |
Post Number: 572 Registered: 7-2006 Posted From: 66.217.107.57
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 12, 2008 - 12:17 am: | |
Ditto Randy's comment. 14-1/4" square is what's usually required! |
Post Number: 187 Registered: 10-2006 Posted From: 66.90.229.32
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 12, 2008 - 6:31 am: | |
On an 06 it is usual to frame with welded supports the opening chopped in the roof. Since the carbunkle air cond will weigh 100lbs plus , and roads are not smooth , a 2 or 3 G loading should be contemplated. FF |
Post Number: 193 Registered: 2-2006 Posted From: 75.196.244.245
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, January 13, 2008 - 1:45 am: | |
Hi Jim, I second ditto Randy's 14 1/4" square. Good Luck Nick- |
Post Number: 57 Registered: 2-2007 Posted From: 24.2.127.94
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, January 13, 2008 - 8:32 am: | |
The vents that I am planning on using use a rough opening of 14 1/4 ". Thanks for everyones help. Jim |
Post Number: 712 Registered: 12-2000 Posted From: 76.3.169.171
Rating:  Votes: 1 (Vote!) | Posted on Sunday, January 13, 2008 - 9:13 am: | |
When deciding where to install the vent (and future AC use), remember that the AC footprint on the roof is much larger than the 14 X 14 opening. Make sure the future AC unit will clear any thing else installed on the roof such as radio & TV antennas, vent stacks, etc. |
