How much does a PD4104 weigh? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2008 » April 2008 » How much does a PD4104 weigh? « Previous Next »
Pat Morse (Paulpat)
Username: Paulpat
Post Number: 7
Posted From: 65.175.208.126
Posted on Sunday, March 16, 2008 - 9:11 am:
I can't find the weight of my bus in the owners manual and was wondering if anyone knows the empty weight of the bus.
Post Number: 265
Posted From: 66.90.229.29
Posted on Sunday, March 16, 2008 - 2:54 pm:
Our Sportscar (4106) was a tiny bit under 20,000 seats out , me in , with the coach heater and Trane air cond yet to be removed.
The 04 had heavier aluminum but a lighter engine, about equal.
AS the registration weight is what the cops use as your "legal weight" when crossing a bridge I would go for 32,000 as thats all the axles/ tires will take.
If you play games and register it at a very light weight , the cops have portable scales they can bring on scene.
Being "overweight" is big buck$.
Greyhound and GM never gave a weight , so they could ship a couple if engines in a bay , without being "overweight".
FF
Username: Kyle4501
Post Number: 403
Posted From: 65.4.176.34
Posted on Sunday, March 16, 2008 - 3:20 pm:
When I registered my dump truck, I talked to the DOT officers in South Carolina. I was told there were 2 weight limits.
1 was the registered weight & the fine for being over that weight was in the hundreds of dollars.
The other was something like the federal highway maximums. The fine for being over that one started in the thousands of dollars & went up from there.
Here is some interesting reading ;)
http://www.fmcsa.dot.gov/rules-regulations/administration/fmcsr/fmcsrruletext.asp?rule_toc =778&section=658.17&section_toc=2135
I decided the extra money up front was good insurance against fines for being over the registered weight.
The whole time I had that truck, I only used it for 'farm' use - mulch for the yard, gravel for the drive way, etc. Not once was I ever stopped by the DOT.
Cable (Fe2_o3)
Username: Fe2_o3
Post Number: 22
Posted From: 71.112.203.229
Posted on Sunday, March 16, 2008 - 7:00 pm:
I don't know if this will help you, but our '53-4104 is a complete conversion. We scale in just under 28000. 10 plus front and 17 plus rear. For license purposes we used 32000, because as Fred said, that is the close to the physical limit, and I don't like fines that cost more than the bus. Cable
Username: Pd41044039
Post Number: 269
Posted From: 71.236.40.26
Posted on Monday, March 17, 2008 - 8:58 pm:
Our completely converted 4104, with full main & aux fuel tanks & water but no waste weighs 24,500.
Glenn Williams (Glenn)
Username: Glenn
Post Number: 148
Posted From: 216.163.57.205
Posted on Tuesday, March 18, 2008 - 8:13 am:
Pat,
Why not just take it to a scale? They are at grain elevators, truck stops, scrap yards and I'm sure that there are many other options. Good Luck!
Glenn
Robert Day (Bigfreight)
Username: Bigfreight
Post Number: 3
Posted From: 63.131.34.57
Posted on Tuesday, March 18, 2008 - 8:22 pm:
In the manuel it says 21,780 lbs for a seated coach but, I don't know if thats with fuel or not. Robert 1953 pd4101-970
Jim Rink (Fakeguy)
Username: Fakeguy
Post Number: 83
Posted From: 192.88.212.34
Posted on Friday, April 25, 2008 - 2:45 pm:
My fully converted 06 with about 50 gals fuel weighs 25,600
