Jerry Campbell (Jerrync)
Registered Member Username: Jerrync
Post Number: 125 Registered: 7-2006 Posted From: 75.176.107.221
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, March 19, 2008 - 7:50 pm: | |
On my bus the door will not close to a seal. It looks good stop but going down the road it will open about 1/4 inch. The air lock will not pull the door in but will keep it from opening.how can I fix this Thanks |
Glenn Williams (Glenn)
Post Number: 149 Registered: 6-2006 Posted From: 216.163.57.205
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, March 19, 2008 - 8:33 pm: | |
On my MCI 7, there is some adjustment possible for the door catch. It is hidden behind a plate that is on the catch itself. There may be one on the piston shaft itself. You may be able to take the play out. How are your door seals? If they are whipped, they would make the problem bigger. Hope this helps! Glenn |
Post Number: 126 Registered: 7-2006 Posted From: 75.176.107.221
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, March 19, 2008 - 8:43 pm: | |
It does help and looking for more and my seals are not good and I am going to order them from MCI unless someone has a better price. If you know Thanks |
Thomas Weeks (Buscrazytom)
Registered Member Username: Buscrazytom
Post Number: 118 Registered: 7-2006 Posted From: 97.81.81.45
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, March 22, 2008 - 8:43 am: | |
I saw a post on the 102A3 door closing issues written by R.J. Long not too long ago. Might want to look it up to see what, if anything, it has to offer for your situation. BusCrazyTom |
David Dulmage (Daved)
Post Number: 199 Registered: 12-2003 Posted From: 142.46.199.30
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 25, 2008 - 11:08 am: | |
Double check to see if there is an override control in operation. On my MC-8 there is a small lever under the dash that disables the air-locking mechanism. DaveD |
