Closed: New threads not accepted on this page |
Thread |
Last Poster |
Posts |
Pages |
Last Post |
  | Pollution Mandates on Rebuilds? | Jim Alexander | 3 | 1 | 4-30-02 5:45 pm |
  | Question for BobM | bobm | 2 | 1 | 4-30-02 5:47 pm |
  | NJ Transit buses | Luke Bonagura | 3 | 1 | 4-29-02 8:51 pm |
  | What a difference 2 cylinders makes | RJ Long | 2 | 1 | 4-28-02 8:51 pm |
  | One More History Please...Thanks RJ | Jim Wilke | 3 | 1 | 4-28-02 11:41 pm |
  | I need DDEC Trans help! | Greg Roberts | 12 | 1 | 4-30-02 6:09 pm |
  | VS2 in 4106 | Scott Whitney | 5 | 1 | 4-29-02 3:34 pm |
  | Codes | Scott Whitney | 27 | 1 | 4-30-02 3:28 pm |
  | 4106 Break Drums | RJ Long | 6 | 1 | 4-29-02 9:24 pm |
  | Do 450+hp Prevosts with 8V92 overheat? | Gary Carter | 9 | 1 | 4-28-02 11:39 am |
  | Experience with JDM Coachbrite | Steven Gibbs | 5 | 1 | 4-29-02 7:24 am |
  | Help on Eagle 10 steering column | Lee Brady | 3 | 1 | 4-26-02 8:17 pm |
  | What demand hot water system is working for you? | OAE Palmer | 5 | 1 | 4-25-02 2:02 am |
  | PROPANE REFRIGERATOR QUESTIONS | George Myers | 10 | 1 | 4-25-02 2:20 pm |
  | Help for a newcomer | Don KS/TX | 2 | 1 | 4-23-02 9:16 pm |
  | Need help converting DD671 to DDEC 671 TA | edwin b | 3 | 1 | 4-29-02 7:39 pm |
  | Hardwood Floors | A&$ | 13 | 1 | 4-30-02 12:54 am |
  | Model Number? | David Pinson | 2 | 1 | 4-23-02 9:19 pm |
  | Fluid type in a allison vh-9? | Don KS/TX | 6 | 1 | 4-25-02 7:09 am |
  | Welding dissimilar metals | Larry Baird | 7 | 1 | 4-23-02 7:00 pm |
  | Mini-Max Brake? | Jim Stacy | 7 | 1 | 4-22-02 9:24 pm |
  | Overheating 4104 | Bubba | 6 | 1 | 4-20-02 8:24 am |
  | Miles Per Gallon and Best Reference guide on conversions | Jayjay | 6 | 1 | 4-26-02 4:15 pm |
  | Rooftop A/C Wiring and mounting | CoryDanesRTSIIIL | 7 | 1 | 4-19-02 4:00 pm |
  | GM PD4106 Heater removal? | Phil Pellowski | 7 | 1 | 4-22-02 5:52 pm |
  | Eagle over the road ac | Jim Nelson | 4 | 1 | 4-20-02 12:57 pm |
  | Rts problem | Jim Stacy | 2 | 1 | 4-18-02 8:27 pm |
  | V730 Fluid Cooler | Dwight | 6 | 1 | 4-21-02 2:13 am |
  | How High can a roof raise go? | Jim Nelson | 4 | 1 | 4-20-02 12:44 pm |
  | RoadRanger Tranny availiable | Gary Stadler | 1 | 1 | 4-18-02 2:35 am |
  | Oxygen bottles on board?????? | Ace | 11 | 1 | 4-20-02 6:23 pm |
  | Newbee Questions about interior walls | Mark Radius | 10 | 1 | 4-22-02 8:13 pm |
  | GVWR - Prevost | Stephen Fessenden | 4 | 1 | 4-16-02 11:53 pm |
  | 8V71 & V730 Over Heat | Dwight | 8 | 1 | 4-19-02 12:39 am |
  | The Complete Neophytes Guide | Loren | 3 | 1 | 4-16-02 3:12 pm |
  | Rust Converter | Scott Whitney | 10 | 1 | 4-15-02 2:49 pm |
  | Eagle 20 roof raise yesterday | tfones | 5 | 1 | 4-14-02 11:30 pm |
  | Inverters | Tom Caffrey | 31 | 1 | 4-19-02 11:34 pm |
  | Fridges | Phil | 21 | 1 | 4-19-02 8:19 am |
  | Two two vehicles | jmaxwell | 3 | 1 | 4-14-02 2:07 am |
  | Can these be towed? | DaveD | 2 | 1 | 4-14-02 9:22 pm |
  | Another history needed RJ | John Dodge | 3 | 1 | 4-13-02 10:45 pm |
  | 8v71 leaks help | Phil Pellowski | 7 | 1 | 4-16-02 12:15 pm |
  | History of bus? Please? | Tom Caffrey | 3 | 1 | 4-13-02 11:21 pm |
  | Yet ANOTHER air leak in the brake system..! | OAE Palmer | 4 | 1 | 4-26-02 5:11 am |
  | A battery question | Keith | 4 | 1 | 4-19-02 2:18 am |
  | 12 volt to 24 volt converter? Or 110vac to 24 vdc inverter | James Nelson | 8 | 1 | 4-15-02 9:28 pm |
  | Bay doors | Doug in FL | 1 | 1 | 4-10-02 12:33 pm |
  | Allison 643 <-> 8v71 <-> Mci-5a, What do I need? | Jim Nelson | 6 | 1 | 4-15-02 9:41 pm |
  | MC 9 N\J transet Bus | Philip Curtis | 4 | 1 | 4-09-02 9:27 pm |
  | PD4501 power steering fluid-what type? | J.L.Vickers | 2 | 1 | 4-08-02 1:17 pm |
  | Possibility here--what do the "experts" think? | DaveD | 8 | 1 | 4-16-02 9:59 pm |
  | Rebuilt engine which has not been used | Joe Shelton | 4 | 1 | 4-15-02 11:28 pm |
  | Power Steering noise | Tom Caffrey | 2 | 1 | 4-07-02 11:21 pm |
  | Tilt column to gear box connection | Ken Munford | 3 | 1 | 4-07-02 7:49 pm |
  | Suspension | Fred batie | 3 | 1 | 4-08-02 10:54 pm |
  | Re suburban furnace problem | evolution custom coa | 2 | 1 | 4-19-02 1:20 pm |
  | Removing spray insulation | Jerry | 3 | 1 | 4-06-02 9:10 am |
  | Leaking fuel tank--help | Louis Kolbe | 11 | 1 | 4-13-02 5:23 pm |
  | Added weight after strip down. | Don Ripley | 12 | 1 | 4-06-02 9:34 am |
  | History on my 4106 | Tom Caffrey | 19 | 1 | 4-13-02 11:27 pm |
  | Pocket doors | Don KS/TX | 8 | 1 | 4-03-02 6:06 am |
  | Suburban propane furnace | DaveD | 9 | 1 | 4-02-02 9:18 am |
  | Diesel Chat | Don Peter | 2 | 1 | 4-01-02 10:25 am |
  | Construction of Partitions | DaveD | 10 | 1 | 4-02-02 10:44 pm |
  | Tilt steering column for 01 | Jason | 2 | 1 | 4-06-02 12:14 am |
  | Use of original side windows | Henry van de Graaf | 10 | 1 | 4-07-02 5:22 pm |
  | Repower project | evolution custom coa | 2 | 1 | 4-19-02 1:28 pm |
  | Do We Give The Seats As Christmas Gifts? | Geoff | 6 | 1 | 4-01-02 9:00 am |
  | MCI 9 operating costs | DaveD | 4 | 1 | 4-02-02 9:23 am |
  | Shipping an 8v71 | jeff | 5 | 1 | 4-03-02 8:04 pm |
  | Need another opinion, again | Jerry | 26 | 1 | 4-04-02 11:42 pm |
  | History of my 4106 | Phil Pellowski | 13 | 1 | 4-16-02 10:55 am |
  | GM Futureliner on Ebay | Jeff | 14 | 1 | 4-03-02 8:14 pm |
  | Raising drivers floor in MCI8 | Jim Nelson | 2 | 1 | 4-15-02 9:59 pm |
  | Is this one any good? | jim | 29 | 1 | 4-01-02 12:59 am |
  | Brake valve leak | mcibus2002 | 16 | 1 | 4-19-02 1:46 pm |
  | 2.5 or 3 ton house heat pump with a/c | evolution custom coa | 3 | 1 | 4-19-02 1:57 pm |
  | Water temp sending unit | Joe Shelton | 6 | 1 | 4-15-02 11:55 pm |
  | Strengthening a front door made from fiberglas - RTS | evolution custom coa | 8 | 1 | 4-19-02 2:05 pm |
  | WHICH MOTOR TO USE | evolution custom coa | 9 | 1 | 4-19-02 2:08 pm |
  | Painting | evolution custom coa | 3 | 1 | 4-19-02 2:17 pm |
  | Building a framework for the caps | evolution custom coa | 4 | 1 | 4-19-02 2:32 pm |
  | Leaking Brake Canister | Richard Jones | 6 | 1 | 4-06-02 4:23 am |
  | Moisture Barrier | Tom Caffrey | 15 | 1 | 4-02-02 12:43 am |
  | Bus Heat | Tom Caffrey | 10 | 1 | 4-02-02 12:52 am |
  | Automatic Slack Adjusters | Tom Caffrey | 14 | 1 | 4-02-02 1:35 am |
  | DD Ser 50 | Jim Nelson | 4 | 1 | 4-15-02 10:16 pm |
  | New batteries and??? | Tom Caffrey | 21 | 1 | 4-03-02 10:47 pm |
  | Generator and Inverter | Peter Broadribb | 15 | 1 | 4-26-02 5:33 am |
  | Wireless Net access on the road | Scott Whitney | 6 | 1 | 4-30-02 9:52 pm |
  | Catalytic heaters | Tom Caffrey | 19 | 1 | 4-05-02 11:07 pm |
  | What a great board!, NO KIDDING! | Tom Caffrey | 7 | 1 | 4-05-02 11:20 pm |
  | Brakes......or the lack there of | Tom Caffrey | 19 | 1 | 4-05-02 11:32 pm |
  | How often should i run my bus | jim | 8 | 1 | 4-05-02 5:27 pm |
  | History of PD 4107 | RJ Long | 12 | 1 | 4-20-02 9:30 pm |
  | Any experience with radiant floor heat in a coach? | Joe Shelton | 8 | 1 | 4-16-02 12:23 am |
  | Arcadia Rally | M.Taylor | 4 | 1 | 4-18-02 10:11 pm |
  | Flxible bus owners | Ken Charleton | 21 | 1 | 4-22-02 7:03 pm |
  | When to change an air bag? | Norm Edlebeck | 4 | 1 | 4-20-02 7:50 pm |
