Closed: New threads not accepted on this page |
Thread |
Last Poster |
Posts |
Pages |
Last Post |
  | "Head" room....... | Don Evans | 3 | 1 | 5-31-02 12:57 pm |
  | Need an opinion on Webasto installation | David Anderson | 9 | 1 | 5-31-02 6:33 pm |
  | Basement A/C question | Tom Hamrick | 6 | 1 | 5-31-02 1:22 pm |
  | Different looking Eagle | David Anderson | 5 | 1 | 5-31-02 10:12 pm |
  | Williams Air Throttle | Paul Tillmann | 4 | 1 | 5-31-02 3:58 pm |
  | DOT and Propane.... | Ross Carlisle | 1 | 1 | 5-29-02 5:51 pm |
  | Coolant Data & Clamps | Scott P. | 2 | 1 | 5-29-02 11:53 am |
  | Ground/neutral bond - an old favorite | David Anderson | 14 | 1 | 5-31-02 10:06 pm |
  | Wiring the speedo & tack | dougthebonifiedbusnu | 5 | 1 | 5-30-02 5:26 pm |
  | Framing for windows | Richard Bowyer | 10 | 1 | 5-30-02 9:19 am |
  | A few questions about re-skinning | gabby | 7 | 1 | 5-31-02 12:53 am |
  | Hitch for RTS | Dwight | 2 | 1 | 5-30-02 7:58 am |
  | Vin's on a 61 /62 eagle WHERE??? | Ace | 2 | 1 | 5-27-02 10:23 pm |
  | Rear end Questions? | Bus Jock | 3 | 1 | 5-31-02 7:47 pm |
  | GMC RTSII slider window screens | FAST FRED | 2 | 1 | 5-28-02 4:40 am |
  | AAA / Good Sam, etc. ????? | Jojo Colina | 8 | 1 | 5-30-02 12:55 am |
  | GM parts compatability between models | Jim Stacy | 2 | 1 | 5-27-02 3:21 pm |
  | Recommended Shops | Mike Eades | 1 | 1 | 5-26-02 1:17 pm |
  | Custom Coach Auction | Scott P. | 2 | 1 | 5-27-02 9:16 pm |
  | How does the low fuel sender work? | David Anderson | 3 | 1 | 5-26-02 1:52 pm |
  | Poo plumbing | Ross Carlisle | 15 | 1 | 5-29-02 3:05 pm |
  | These pages should be required reading... | Gary Stadler | 4 | 1 | 5-26-02 3:23 pm |
  | Springfield, Ohio Get Together | George Myers | 4 | 1 | 5-26-02 7:47 pm |
  | Power Steering ? For Luke or Anyone | Tom Caffrey | 4 | 1 | 5-26-02 6:05 pm |
  | HOME POWER J/J | FAST FRED | 8 | 1 | 5-25-02 5:47 am |
  | Can I Tow a 96 GMC JIMMY? | Peter Broadribb | 6 | 1 | 5-24-02 7:30 pm |
  | Accessories | Johnny | 2 | 1 | 5-26-02 2:00 pm |
  | RTS Highway Gears | jmaxwell | 4 | 1 | 5-23-02 11:36 pm |
  | Rules and "Netiquette" | Peter | 8 | 1 | 5-24-02 1:14 pm |
  | Worm Gear Adjustment on Sheppard ? | Frank Allen | 4 | 1 | 5-24-02 9:17 am |
  | Generator exhaust system | Jayjay | 5 | 1 | 5-30-02 1:58 am |
  | Adding 12V Alternator to 4905 | Don KS/TX | 6 | 1 | 5-26-02 2:45 pm |
  | Wall insulation idea | Peter Broadribb | 3 | 1 | 5-22-02 4:24 pm |
  | Kool-seal , any good? | dounanpm | 19 | 1 | 5-27-02 5:49 am |
  | Heating my skoolie--part 2 | Tom Caffrey | 9 | 1 | 5-23-02 10:55 pm |
  | 300amp alternator | Gary Stadler | 27 | 1 | 5-24-02 1:20 am |
  | Power steering on 4905 | bill chisholm | 6 | 1 | 5-22-02 12:01 pm |
  | Smooth Sides | Jim Nelson | 4 | 1 | 5-28-02 6:09 pm |
  | Bus is now Motorhome | MC - Iv | 3 | 1 | 5-20-02 3:13 am |
  | Pruned the bbs and archived a ton | R.C.Bishop | 5 | 1 | 5-19-02 10:23 pm |
  | Added weight to rear of coach | Richard Bowyer | 9 | 1 | 5-30-02 6:24 pm |
  | Some people are just stupid........ | Jocelyne Costello | 18 | 1 | 1-10-05 4:17 pm |
  | GCVWR on a skoolie? | Scott P. | 2 | 1 | 5-19-02 4:36 pm |
  | Air System Problem MC5C | Paul Tillmann | 2 | 1 | 5-19-02 3:50 pm |
  | Short Bus- Any Good | John G Root Jr | 56 | 1 | 5-25-02 2:10 pm |
  | Suburban Furnace Installation | Ross Carlisle | 3 | 1 | 5-17-02 9:47 pm |
  | Cheap Trick / GMC Coach Hitches | Mike Eades | 18 | 1 | 5-18-02 5:30 pm |
  | Windshield wipers | Gary Langley | 5 | 1 | 5-17-02 5:38 pm |
  | Generator location | Gary Langley | 5 | 1 | 5-17-02 5:54 pm |
  | We have lost a friend | Linda 4104 | 14 | 1 | 5-18-02 12:03 am |
  | Brake Job | Dave-9-Fl | 3 | 1 | 5-15-02 10:40 pm |
  | Additional questions for a 12 volt vs 24 volt | Tom Caffrey | 5 | 1 | 5-16-02 10:16 pm |
  | DANGER , in your FIRE EXTINGUISHER? | Derv | 6 | 1 | 5-19-02 7:35 pm |
  | Heat with a what? | Johnny | 12 | 1 | 5-18-02 1:43 am |
  | Battery charging. | MC - Iv | 11 | 1 | 5-19-02 11:15 pm |
  | Need Help | Skip Wood | 1 | 1 | 5-15-02 12:37 am |
  | Gen light | Jerry | 2 | 1 | 5-15-02 12:34 am |
  | Energeystar.gov | Stephen Fessenden | 9 | 1 | 5-15-02 6:57 pm |
  | Water tank insulation | Tom Caffrey | 7 | 1 | 5-17-02 12:17 am |
  | Pintle hitch? | Mike Eades | 5 | 1 | 5-14-02 8:14 am |
  | Glue for headliner material? | steve souza | 8 | 1 | 5-20-02 7:56 pm |
  | Raising the roof on a MCI-9 | Ross Carlisle | 2 | 1 | 5-12-02 10:12 pm |
  | Eagle bus corten steel. | Linda 4104 | 9 | 1 | 5-14-02 12:16 am |
  | Flat ceiling construction | C. Ray Powell | 13 | 1 | 5-20-02 9:39 pm |
  | Automated sliding pocket door | Scott Whitney | 8 | 1 | 5-14-02 2:10 pm |
  | House electrical | Dwight | 2 | 1 | 5-11-02 8:46 am |
  | Composting Toilets | CoryDaneRTSIIIL | 11 | 1 | 5-12-02 9:13 pm |
  | Lots of questions about an MCI5A conversion | Horseman | 12 | 1 | 5-13-02 3:05 pm |
  | Looking for pre-war Yellow Transit Buses | OAE Palmer | 4 | 1 | 5-22-02 1:25 am |
  | 24 volts vs 12 volts | Buswarrior | 6 | 1 | 5-14-02 1:23 am |
  | Air conditioner /heater problems | Jim Nelson | 2 | 1 | 5-12-02 9:36 pm |
  | Hmmmm. Is this doable? How about practical? | Stephen Fessenden | 5 | 1 | 5-10-02 10:03 pm |
  | Air bags, replacing rubber only: anybody done it? | Jim Ashworth | 5 | 1 | 5-11-02 9:03 am |
  | Roof top air conditioners? | Ross Carlisle | 3 | 1 | 5-09-02 1:08 pm |
  | Soundproofing Genset | Scott Whitney | 5 | 1 | 5-09-02 10:26 pm |
  | Levelling the bus for the Fridge...or not... | Scott Whitney | 9 | 1 | 5-11-02 1:04 pm |
  | MC9 inner panels... | Buswarrior | 6 | 1 | 5-14-02 1:31 am |
  | CALIFORNIA ASSEMBLY BILL 1058 hurts BAD! | Bobby Sather | 11 | 1 | 5-12-02 12:35 am |
  | HISTORY OF 4104 | J.L.Vickers | 2 | 1 | 5-09-02 12:22 am |
  | Tankless water heater? | OAE Palmer | 12 | 1 | 5-09-02 8:50 pm |
  | Lug nuts - Left hand and right hand | Jim Nelson | 5 | 1 | 5-12-02 9:22 pm |
  | So just where exactly is the O.C. Bus convention? | peter | 3 | 1 | 5-07-02 4:57 pm |
  | Sloppy Shepard, help? | Gary Carter | 3 | 1 | 5-11-02 9:24 pm |
  | Fan Drive for 6v92 | Skip Wood | 1 | 1 | 5-06-02 11:35 pm |
  | 4104 STEERING | Jim Stacy | 2 | 1 | 5-07-02 8:30 pm |
  | IT RUNS!!!!!! | Ross Carlisle | 9 | 1 | 5-08-02 11:45 am |
  | Retreads | dougthebonifiedbusnu | 10 | 1 | 5-14-02 8:59 pm |
  | Towing or hauling a bus | George Webber | 21 | 1 | 5-10-02 1:56 pm |
  | How to Grind down spray-foam insulation? | DaveD | 12 | 1 | 5-08-02 1:58 pm |
  | Alternator | Tom Caffrey | 9 | 1 | 5-06-02 10:51 pm |
  | Trans. Oil light came on! (4905 with Allison V730) | peter | 2 | 1 | 5-06-02 3:00 pm |
  | Is this a dumb question? (about diesel braking) | Dwight | 16 | 1 | 5-11-02 9:38 am |
  | Computer camera for rear view? | Brian | 16 | 1 | 5-10-02 2:39 pm |
  | Drip rail | R.C.Bishop | 2 | 1 | 5-03-02 10:01 pm |
  | Other Bulletin Boards | Scott Whitney | 3 | 1 | 5-04-02 1:14 am |
  | Basement Air Installation | bobm | 11 | 1 | 5-10-02 10:59 am |
  | Generator cut-off Switch | Mike Eades | 6 | 1 | 5-15-02 9:53 am |
  | I think I found my future motor coach......... | Johnny | 11 | 1 | 5-07-02 11:07 pm |
  | How about a couple more.......? | Ray Olson | 3 | 1 | 5-03-02 10:41 am |
  | Peninsula Install Questions | Jim Ashworth | 2 | 1 | 5-03-02 9:26 am |
  | 4104 history ? | dounanpm | 5 | 1 | 5-03-02 6:06 pm |
  | Vin 's on an eagle | fbatie | 3 | 1 | 5-02-02 9:16 pm |
  | Aqua Hot/Webasto isolation valves | joe shelton | 16 | 1 | 5-16-02 12:44 am |
  | 6V92 | Johnny | 5 | 1 | 5-08-02 3:53 am |
  | Tile in Galley and head areas.... | R.C.Bishop | 10 | 1 | 5-03-02 10:25 am |
  | Here's an interesting one: alternator alternative... | Stephen Fessenden | 3 | 1 | 5-03-02 12:33 am |
  | Converted MC9 GVW | Mike Kennedy | 4 | 1 | 5-02-02 11:18 pm |
  | Interesting Idea - Feasible? Legal? | Buswarrior | 7 | 1 | 5-11-02 10:57 am |
  | LOST COOLING WATER/ PREVOST | FAST FRED | 3 | 1 | 5-02-02 4:47 am |
  | You Just Can't Go Home Again..... | OAE Palmer | 3 | 1 | 5-01-02 11:25 pm |
  | Spinning tank fittings | Gary Stadler | 5 | 1 | 5-15-02 12:59 am |
  | Air Brakes | Jim Nelson | 8 | 1 | 5-05-02 8:58 pm |
  | Volunteer skoolie? | Ray Olson | 4 | 1 | 5-02-02 7:16 pm |
  | Hmmm. Maybe..................... | Brian | 17 | 1 | 5-10-02 6:04 pm |
  | Furniture, salvage or new around Chicago/Indiana | C. Ray Powell | 5 | 1 | 5-01-02 7:00 am |
  | Speaking of codes, how'bout exhaust location? | Brian | 7 | 1 | 5-10-02 2:54 pm |
  | Resale Value Revisited or You Want How Much? | FAST FRRED | 23 | 1 | 5-03-02 5:31 am |
  | HOT WATER TROUBLE? | DaveD | 11 | 1 | 5-02-02 2:38 pm |
  | Temp fix for air leak | RJ Long | 23 | 1 | 5-16-02 4:00 am |
  | Can slideouts be adjusted ? I have a crease in my carpet | DaveD | 2 | 1 | 5-03-02 1:12 pm |
  | Doug Wooden | Ace | 3 | 1 | 5-07-02 5:17 pm |
  | Internet available on university commuter bus | Scott Whitney | 8 | 1 | 5-10-02 1:03 pm |
  | 4104 rear window? | jeff MacMakin | 6 | 1 | 5-02-02 11:03 am |
  | CDL and coaches | MCI-96A2 | 36 | 1 | 5-15-02 6:40 am |
  | Foamed my bus today | mike heron | 16 | 1 | 5-17-02 10:54 am |
