Barry McCully (Turtle)
Registered Member Username: Turtle
Post Number: 16 Registered: 8-2007 Posted From: 71.7.213.91
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, April 07, 2008 - 5:14 am: | |
I just started my 9 up and moved it around the yard after sitting all winter the left side aired up the the right side didn't is there a level valve I should check if there is where would it be.Thanks |
Post Number: 744 Registered: 12-2000 Posted From: 70.0.64.22
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, April 07, 2008 - 9:07 am: | |
Front leveling is above the center of the front axle. The rear leveling valves are above each end of the drive axle (in front of the air bags). Each valve will have a linkage that attaches to the axle. Jack PS: BLOCK UP THE BUS BEFORE CRAWLING UNDER IT!! |
Ednj (Ednj)
Post Number: 185 Registered: 3-2003 Posted From: 67.85.229.150
Rating:  Votes: 1 (Vote!) | Posted on Monday, April 07, 2008 - 3:30 pm: | |
What Jack said. The rear valves control side to side, the front only up&down |
Post Number: 1001 Registered: 10-2003 Posted From: 71.58.48.5
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, April 07, 2008 - 5:50 pm: | |
Is the temp below freezing when you aired it up; or below freezing the night before? could be ice formed in one of the small lines or valves. Do you hear a good bit of hissing on that low corner? |
