Geobus (4108gmc)
Registered Member Username: 4108gmc
Post Number: 63 Registered: 6-2004 Posted From: 75.230.41.114
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, April 28, 2008 - 7:42 pm: | |
Looking for a good place to get a new steering wheel and a replacement driver's seat for my 4108 gmc. Any suggestions where to look? Have a great day. |
Post Number: 241 Registered: 3-2007 Posted From: 76.4.151.87
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, April 28, 2008 - 8:24 pm: | |
I found a steering column at at truck salvage yard that was out of a snub nose fire truck. It had all the goodies like tilt,telescopic,turn,light,windshield wipers[electric] washer.smaller wheel. I took my 4905 out and with a little fitting it works perfect. gomer |
Post Number: 1090 Registered: 10-2003 Posted From: 71.58.48.228
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, April 28, 2008 - 11:06 pm: | |
VIP makes replacement steering wheels in different styles and diameters and leather covered. |
Post Number: 304 Registered: 10-2006 Posted From: 208.100.193.188
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, April 29, 2008 - 3:47 pm: | |
If you're near CT I have a seat , but not the post. FF |
Geobus (4108gmc)
Post Number: 64 Registered: 6-2004 Posted From: 75.230.66.127
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, April 29, 2008 - 4:21 pm: | |
What kind of seat do you have? Is it too much to ship? Have a great day. |
FloridaCliff (Floridacracker)
Post Number: 380 Registered: 7-2004 Posted From: 24.27.228.156
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, April 29, 2008 - 4:47 pm: | |
Gomer, Where is there a truck salvage yard around our area? Cliff |
Post Number: 1092 Registered: 10-2003 Posted From: 71.58.48.228
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, April 29, 2008 - 7:41 pm: | |
change it to a used truck air ride seat, you'll never be sorry. At least use the lower air ride part and attach the seat of your choice. |
Post Number: 166 Registered: 10-2003 Posted From: 66.165.176.60
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, April 30, 2008 - 9:51 am: | |
I'll second John's recomendation. I love my air ride seat |
Post Number: 1283 Registered: 12-2000 Posted From: 76.68.120.21
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, May 03, 2008 - 8:16 am: | |
Hello. Yes, air ride seats smooth out a long drive! However, if you haven't used one, when selecting your air ride seat, care must be taken to be sure its motion is properly dampened. An older seat may require replacement parts for the shock absorber function, and be aware that there were some less expensive seats manufactured that had fairly unrestricted movement. These will fool the novice into thinking it is "better", as it moves up and down more easily when you try sitting in it. Trouble is, when you go over a sizable bump, the seat travels easily up and then harshly bottoms out, jolting you against the seat base. This is no good. If you don't have neck and back trouble now, it will give you some! A poorly dampened chair also makes clutch work a little tricky, the seat rises as you try to push down on the clutch. Like every other good thing, you have to watch what you are doing! happy coaching! buswarrior |
Post Number: 1109 Registered: 10-2003 Posted From: 71.58.48.228
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, May 03, 2008 - 8:08 pm: | |
If you time the up and down ocsilations right,Push in the clutch when coming down and leave up when coming up.  |
Post Number: 237 Registered: 10-2004 Posted From: 96.232.83.216
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 04, 2008 - 11:51 am: | |
Cliff, there was a small yard in Reddick nof Ocala, but its been awhile, and Tampa area Riverveiw and Sefner had some, maybe Bushnell still has something, And Wildwood on 301south of the big road. Most trucks are picked clean pretty quick. |
