Dolly towing Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2008 » May 2008 » Dolly towing « Previous Next »
Larry & Lynne Dixon (Larry_d)
Username: Larry_d
Post Number: 143
Posted From: 71.111.188.44
Posted on Tuesday, May 20, 2008 - 1:08 am:
Hello frendly bus nuts---- I think I am going to tow my van on a dolly with turn table. Do you lock the front wheels of the van while towing? The turn table is quite stiff but I will try to grease with something first, Thanks ever so much for all the help you all have been 4905 Larry
Also regards the loud bang from rear of coach I still have found nothing.
Edward J. Sommers (Sommersed)
Username: Sommersed
Post Number: 30
Posted From: 148.78.155.174
Posted on Tuesday, May 20, 2008 - 9:52 am:
The "turntable" serves the same purpose as your tires turning so Yes, you can lock the steering in your case.
Ed
Larry Higuera (Larryh)
Username: Larryh
Post Number: 28
Posted From: 148.78.52.146
Posted on Tuesday, May 20, 2008 - 9:56 am:
Larry Dixon
I take it from your post your towing it backwards rear wheels on dolly. Then by all means front wheels must be secured in the straight ahead position. I use the seat belt to secure steering wheel put at least one full loop around steering wheel.
Username: Oonrahnjay
Post Number: 238
Posted From: 149.168.204.4
Posted on Tuesday, May 20, 2008 - 11:06 am:
Larry Higuere wrote: "I take it from your post your towing it backwards rear wheels on dolly. Then by all means front wheels must be secured in the straight ahead position. I use the seat belt to secure steering wheel put at least one full loop around steering wheel."
__. Right! I don't know much about diesels but I can tell you thing or two about passenger cars. And one of those is that the "steering lock" on cars is meant to be anti-theft (well, really only strong enough to slow a thief down enough to make stealing your car less practical). If you're towing rear-wheels-up and the front wheels are on the ground (either a dolly or a tow truck), you're inviting breaking the steering lock. That will leave you with 1) unlocked wheels and your towed vehicle doing who knows what, and 2) a broken streering column/ignition switch.
__. Both of these conditions could be described as "not too good". You really should use a secure steering wheel stop.
Username: Larry_d
Post Number: 144
Posted on Tuesday, May 20, 2008 - 2:26 pm:
Hi everyone it seems I always forget to mention something. The van is a late model front wheel drive van and auto tranny. Van is quite heavy but don't have the want to buy another vehicle to tow all wheels down. Thanks so much all, I had an idea this was the answer but more heads are better than one. Thanks 4905 Larry
Post Number: 239
Posted on Tuesday, May 20, 2008 - 4:38 pm:
__. OK, you you're going to tow it front-wheels-up on the dolly? That works, in fact with the engine and drive line (weight) up front, it should work very well indeed.
Username: Gusc
Post Number: 666
Posted From: 208.54.200.36
Posted on Tuesday, May 20, 2008 - 5:10 pm:
Larry,
Keep in mind that there is no way you can back up with a dolly so keep yourself out of any tight spots.
Username: Bigrigger
Post Number: 71
Posted From: 24.197.246.104
Posted on Tuesday, May 20, 2008 - 5:58 pm:
Larry, we have towed our Honda Odessy all over with a dolly and have had no problems. Just make sure the wheels are secure on the dolly plates and check the straps several times as they tend to loosen up with driving. The other thing you might consider is a c0ver for the front of the van. If your bus smokes at all(and most diesels do) it will make a mess of the van .
Username: John_mc9
Post Number: 605
Posted From: 66.217.102.43
Posted on Tuesday, May 20, 2008 - 7:40 pm:
We towed our Caravan all over, all four down, by using the
Remco transmission pump. It's alot easier four down, than
to have to go through the unhook/rehook procedure with a
dolly.... BTW, alot of campgrounds now charge extra for a dolly!
Remco Lube Pump
(Message edited by john_mc9 on May 20, 2008)
Steven M. Toomey (Pabusnut)
Username: Pabusnut
Post Number: 6
Posted From: 71.207.107.232
Posted on Tuesday, May 20, 2008 - 7:43 pm:
Like some other folks said "remember you can't back up"!!
If you plan your trip well, you won't have to back up, but..... Murphy intervenes!
I would recommend becoming proficient at unloading and re-loading the van on the dolly.
Don't ask me how I know!!
Ednj (Ednj)
Username: Ednj
Post Number: 191
Posted From: 67.85.229.150
Posted on Tuesday, May 20, 2008 - 9:24 pm:
Hello frendly bus nuts---- I think I am going to tow my van on a dolly with turn table. Do you lock the front wheels of the van while towing? The turn table is quite stiff but I will try to grease with something first, Thanks ever so much for all the help you all have been 4905.
Larry,
I have a Stehl tow dolly with the turn table and YES you HAVE to leave the steering wheel UNLOCKED.
When you make a turn the steering wheel turns and the dolly tires and the toad rear tires take a different track.
Making a shaper turn and not scrubbing the tires.
Username: John_mc9
Post Number: 606
Posted From: 66.217.105.177
Posted on Wednesday, May 21, 2008 - 10:00 am:
Larry-
Sorry, I didn't read your question correctly! I thought you were
just considering to use a dolly, not that you already chose to....
That said.... You may want to research things a bit further regarding
locking the steering or not. See: Towing 101
That's just one website among many, that explains proper rv/dolly towing.
Your best bet, would be to contact your dolly's manufacturer for
their detailed instructions and requirements. Making a simple mistake
with the initial hook-up can bring not-so-nice consequences!
Ednj (Ednj)
Username: Ednj
Post Number: 192
Posted on Wednesday, May 21, 2008 - 10:07 am:
John,
That article totally contradicts what STEHL Tow sayes.
But like you said check with the dolly manufacturer.
Username: John_mc9
Post Number: 607
Posted From: 66.217.100.125
Posted on Thursday, May 22, 2008 - 10:26 am:
Ed-
Hope youse didn't take it personal....
When we were considering the method of dragging along our
van, I found so much contradiction among users, manufacturers
and dealers, that I felt mentioning it now, might save the guy some
headaches.
A friend that dollied (full-time/10 years), convinced me to tow
four-down, giving me all his bad experiences using a dolly...
The first time we drove into a mis-marked campground entrance,
at night, in the rain, towing four-down.... well... It convinced me
that we made the right choice! I don't think it took a minute to unhook,
and maybe another two to re-hook.
To each, our own.... I 'spose..
