E. R. Red Ruby (Beatsworkin)
Registered Member Username: Beatsworkin
Post Number: 18 Registered: 2-2006 Posted From: 76.253.188.72
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, June 13, 2008 - 4:00 pm: | |
My muffler is the big round one that is behind the rear axle but in front of the motor. I have two questions. 1.How do you get to the bracket that supports the muffler 2. Because a new muffler is pricy what have some of you done instead of replacing with new. |
bill chisholm (Billybandman)
Registered Member Username: Billybandman
Post Number: 131 Registered: 2-2001 Posted From: 198.236.64.24
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, June 13, 2008 - 4:11 pm: | |
To get to the muffler there is a removable piece of floor above the muffler that must be opened from the inside of the bus. It ook mine to a welder and had him weld a bunch of new baffles and reinforce the outside with some new steel. It has been there 15 years with no problems. |
Douglas Wotring (Tekebird)
Post Number: 359 Registered: 10-2004 Posted From: 71.59.75.212
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, June 13, 2008 - 4:44 pm: | |
GM mufflers are rebuildable providing the ends are in good shape |
Post Number: 1184 Registered: 10-2003 Posted From: 71.58.110.9
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, June 13, 2008 - 5:28 pm: | |
A lot of the 4905's, at least, have the muffler mounted vertical by the left of engine in engine compartment, right inside the engine door by the radiator fan shroud. Some have voiced concern for a fire starting in your muffler location if a hole in the upper end blows exhaust against floor. Apparently, this has happened. The problem with the alternate location at the rear is obstructed access to fan and water pump area. Your muffler hangs by a large stud with rubber grommets similar to the end of the older shock absorbers. You may be able to unbolt the channel that the stud goes through from below, however I'm unsure about this point. |
Bob Wies (Ncbob)
Registered Member Username: Ncbob
Post Number: 257 Registered: 2-2006 Posted From: 70.220.218.204
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 16, 2008 - 6:55 am: | |
If it's ideas you're looking for you might wish to check with Florida Cliff who is on vacation at this time but left a pretty detailed description and pictures of the dual muffler system he installed on his 4905. I can't be sure but I think most of what he did is posted on the MAK board. a simple search of their archives should help. Too he listed the Mfr. of the mufflers he used and Rock Auto, the jobber who quoted him the best prices. FWIW Bob |
Bob Baldwin (Bob4106)
Registered Member Username: Bob4106
Post Number: 154 Registered: 10-2004 Posted From: 24.74.180.20
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 16, 2008 - 4:21 pm: | |
My be this will be helpful |
