Need help hooking up inverter to batt... Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2008 » June 2008 » Need help hooking up inverter to batteries « Previous Next »
John Elnitski (Ski43)
Username: Ski43
Post Number: 9
Posted From: 71.58.59.233
Posted on Friday, June 27, 2008 - 12:47 pm:
I plan on hooking up my house batteries to a switch. I will be able to
switch between off, sending 12 vdc to 12 vdc devices, sending 12 vdc to
my inverter or sending 12 vdc to both. If I have the switch set to
both and the inverter is charging my house batteries, will the charging
cycle by the inverter damage my 12 vdc devices.
Username: Lsilva
Post Number: 151
Posted From: 71.99.27.221
Posted on Friday, June 27, 2008 - 3:39 pm:
John, You don't ever want to disconnect the batteries from the inverter/charger and you don't want more than 4-5 feet of cable between the batteries and inverter.
It's OK to have a switch between the batteries and your 12 volt equipment.
The inverter charging won't hurt any 12 volt equipment, just be sure to disconnect any 12 volt equipment if using the equalize function of your charger.
Len
Post Number: 390
Posted From: 208.100.193.238
Posted on Saturday, June 28, 2008 - 6:14 am:
That switch had better be a $80+ good marine switch IF the inverter will pull thru it.
FF
Username: George_mc6
Post Number: 479
Posted From: 207.231.75.253
Posted on Saturday, June 28, 2008 - 10:55 pm:
John,
Are you aware that 10 amps of 120 Volts AC will require 120 Amps of 12 Volt DC? That's if the inverter is 100% efficient, which it isn't. Actual current draw will be about 130 amps!
All of your 12 Volt appliances are made to run on charging voltage, as they do while you are driving.
I don't see the need for a switch, but if you do, it will have to be rated for 300 Amps, or it will disappear in a cloud of smoke! Needless to say, your cables and connections will have to be able to handle this amount of current also!
Regards,
George
