james (Dieseldust)
Registered Member Username: Dieseldust
Post Number: 25 Registered: 3-2007 Posted From: 75.155.124.160
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, July 09, 2008 - 2:02 pm: | |
hello to all can anyone tell me what this bus is make and model ? and where they a good bus, it has a 453 Detroit. Cheers James |
Douglas Wotring (Tekebird)
Post Number: 370 Registered: 10-2004 Posted From: 71.59.75.212
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, July 09, 2008 - 5:35 pm: | |
Orion I at the time it was a cheap/small capacity transit. decent unit I guess for what it was intended. What are your plans |
james (Dieseldust)
Post Number: 26 Registered: 3-2007 Posted From: 75.155.124.160
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, July 09, 2008 - 11:12 pm: | |
Douglas i found it for sale and it has been parcialy converted to the point where you can tour in it, but i know nothing about them, i know it is a darn small engine maybe good maybe bad lololo,it was a comuter bus and i know it can cruise at 65 ok,any information about the orion,s would be great. Cheers James |
Post Number: 89 Registered: 9-2007 Posted From: 24.197.246.104
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, July 10, 2008 - 8:13 am: | |
James, I don't know anything about orions, but if it suits what you want in a bus, go for it. Detroit has built engines for many years and should be reliable enough. IF it was designed for sale as a commuter bus, it should have a reasonably long life expectency. I would always check the undercarraige and frame for rust issues. That can be a real killer. Good luck! |
Post Number: 197 Registered: 4-2001 Posted From: 70.1.21.175
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, July 10, 2008 - 10:23 am: | |
Any -53 series is going to be a screamer. Instead of 2100 RPM's think in terms of 2650 RPM's. |
Arthur N. Gaudet (Runcutter)
Registered Member Username: Runcutter
Post Number: 11 Registered: 9-2006 Posted From: 76.185.242.7
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, July 10, 2008 - 2:21 pm: | |
James, you might want to double-check, and look for a builder's plate somewhere. From that angle, it looks a lot more like a Twin Coach TC-25 than an Orion. I've run both, and the Orion's corners are more rounded. Also, it looks short enough (again, indicative of a TC-25), which would be consistent with only a 4 cylinder engine. Some properties had problems with the 6-53 (six cylinders, 53 cubic inches per cylinder). When I was on a property that had some Twins (late 1970's), I don't remember any issues, but we only used them in light service - and converted two to lift-equipped demand response vehicles. Arthur (Message edited by runcutter on July 10, 2008) |
james (Dieseldust)
Post Number: 27 Registered: 3-2007 Posted From: 75.155.124.160
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, July 10, 2008 - 3:53 pm: | |
mdyr 11/1973, make TWINC, and body 4Bus. this is what is on the registration cant get to the bus to see the tag on the bus. |
james (Dieseldust)
Post Number: 28 Registered: 3-2007 Posted From: 75.155.109.13
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, July 11, 2008 - 3:53 pm: | |
Has anyone had any expieriance with 453 engines, i have driven lots of diesel engines before including 8v71 ,and 8V92 in big trucks and bus, but never the 453, i know it is a small engine not big horse power or torque , but i dont need to go fast up hills anymore, any imput would be great, i would imagine they might be good on fuel. Cheers James |
Post Number: 697 Registered: 11-2005 Posted From: 208.54.200.228
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, July 12, 2008 - 4:47 pm: | |
Mark is correct, this is one of the noisiest engines known to mankind. It was used in military vehicles, water pumps, generators and Ford installed it in some pickups for a few years, around '56-'58 I think. |
Post Number: 698 Registered: 11-2005 Posted From: 208.54.200.228
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, July 12, 2008 - 4:49 pm: | |
(Message edited by gusc on July 12, 2008) I tried to delete the duplicate post and got this message?? Is this weird or what? "Sorry, but the message you were attempting to delete was posted more than 0 minutes ago. You are not permitted to delete messages more than 0 minutes old. If the message needs to be deleted, contact a moderator, who can delete the message for you through the administration program." (Message edited by gusc on July 12, 2008) |
Post Number: 2067 Registered: 1-2001 Posted From: 75.108.85.14
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, July 12, 2008 - 4:59 pm: | |
It has been that way since Ian installed the new board several months ago. It will at least let you edit the post, which I do if something is wrong with my post. Richard |
Post Number: 1392 Registered: 12-2000 Posted From: 67.181.166.160
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, July 13, 2008 - 6:26 pm: | |
James - Look very, very carefully around the wheelwells, both inside and outside the coach. For awhile the charter outfit I worked for shared a yard (while their local terminal was being built) with a rebuilder who refurbished a bunch of these little TCs. Nearly every one had really soft flooring from water getting to the floor from underneath, some of which extended clear across the coach. Rust was also found it the tube framing, especially around the windows - again where water had leaked inside. Pretty gutless, too. . . Top speed on this batch was all of 50 mph - perfect for light-duty transit work in suburban areas, not so good as a highway hauler. Your $$. . .your choice. . . FWIW & HTH. .
james (Dieseldust)
Post Number: 29 Registered: 3-2007 Posted From: 75.155.109.13
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, July 13, 2008 - 9:18 pm: | |
Thanks RJ, I will check it out and i am sure they are gutless, this was a comuter coach and ran on the HWY, so i would imagine it must be geared for the HWY i hope, the bus is in seattle i am about 3 hours away in Canada, it is a estate sale,so there is not much known about it. Cheers James |
Post Number: 1393 Registered: 12-2000 Posted From: 67.181.166.160
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, July 14, 2008 - 12:28 am: | |
James - Time to throw a monkey wrench into all of this: Transport Canada may not allow you to import this coach! If they were never approved for sale, or imported into Canada while they were in production, chances are slim to none that you'll be able to bring it across the border on a permanent basis, especially since it apparently no longer has a seated coach interior. Better do some more homework before you take any plunge on this vehicle. Surrey, BC, eh? My daughter went to Trinity Western in Langley, now lives in Kelowna. FWIW & HTH. . .
james (Dieseldust)
Post Number: 30 Registered: 3-2007 Posted From: 75.155.109.13
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, July 14, 2008 - 10:23 am: | |
You are right RJ, i have been looking for awile for a bus and i forgot all about that,the bus has to be older than /January/1971 ,if it has been altered.That law sucks. oh well i have to keep looking,The bus is in seattle if anyone is interested it is 80 % finished inside and out and they are asking 5000 and very open to offers,if anyone is interested email me and i will send you the pictures and contact information. Cheers James |
Post Number: 276 Registered: 6-2004 Posted From: 66.38.159.33
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, July 16, 2008 - 10:14 pm: | |
James Orion approved for import are restricted to 1995 and newer models, all others are on the inadmissable list. I was at Ritchie Bross Auction this aft to check what stuff went for two weeks ago while I was on the other side of the big pond. Three MCI classic 1992 transits with newer 6/92 went for 1750 and 2000 dollars. Relativly cheap. Keep looking!!! The right one is out there. Joe. |
james (Dieseldust)
Post Number: 31 Registered: 3-2007 Posted From: 75.155.109.13
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, July 17, 2008 - 5:55 pm: | |
Hello Joe how are things in Alberta, wow seems like some buses are going very cheap, i heard in Kamloops there where some old MCI that went for 2000 to 2500 , and they all just came of of the road. Cheers James |
Post Number: 290 Registered: 6-2004 Posted From: 66.38.159.33
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, August 17, 2008 - 7:12 pm: | |
James I received an email from a lurker out of New Brunswick and he mentioned that Orion 1's to 5's are permisable for importation. The reason is they were built by Ontario bus Industrius (bus industries of america) There may have been a corporate reorganization so they show up on the RIV list under two different listings. Other forum members may know more about this. Joe. |
