John Lacey (Junkman42)
Post Number: 47 Registered: 3-2007 Posted From: 69.19.14.18
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, July 13, 2008 - 9:54 pm: | |
Does anyone know if there are any support points between the belcrank at the engine and at the forward pedal linkage that can or should be lubricated? Having trouble with the throttle not quite returning and having to step on the bottom of the pedal to get jakes and idle. Help,John |
Post Number: 785 Registered: 12-2000 Posted From: 76.3.173.51
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, July 14, 2008 - 8:00 am: | |
We eliminated the problem by replacing the mechanical linkage in our MC-8 with an air throttle. Look at the lubrication chart in your service manual, it should show all throttle linkage lubrication points. Jack |
J.C.B. (Eagle)
Registered Member Username: Eagle
Post Number: 142 Registered: 12-2000 Posted From: 166.214.245.53
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, July 14, 2008 - 8:20 am: | |
John it could be the swivel point at the bottom of the throttle pedal that is where my problem was. |
Grant Thiessen (Busshawg)
Post Number: 35 Registered: 10-2007 Posted From: 206.45.93.160
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, July 14, 2008 - 12:23 pm: | |
I have also had the same problem at the base of the pedal |
