mike sweet (209.190.8.86)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, June 16, 2002 - 6:30 am: | |
84 Eagle won't restart after it been running a while. Turns over good but just won't start. 30 min. later she cranks right up. While running all guages show good stats. Only thing that has been done since this problem arised is the bus air removed and main heater cores. Not sure if this is related or not. |
Donn (63.10.133.234)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, June 16, 2002 - 8:56 am: | |
Mike' If you have an air operated shutdown ,you might want to check that it is releasing it's air after shutdown.If it isn't the fuel cut off will remain off untill the pressure bleeds down.Hope this helps -Donn |
