Buddy Tennison (Buddyten)
Post Number: 71 Registered: 7-2005 Posted From: 207.68.239.252
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 19, 2008 - 11:48 pm: | |
Hey Guys I have discovered that one of the relays on my 80 Eagle must be going bad. It "clicks" and causes the lights to slightly blink. I went to the NAPA parts house today to see if they had one. The number on it is 969-12V and is a Delco-Remy brand. They could not find such an animal. Do any of you have any experience with this and if so, is there a cross-reference or where might I be able to get one of these things? |
Jack Campbell (Blue_goose)
Post Number: 101 Registered: 5-2007 Posted From: 71.100.201.35
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 20, 2008 - 8:43 am: | |
When it clicks what is it doing. Is it going open or closed. It could be going open because the bracker opened because of a short. I have had this problem in the past and it was because of a short. you need to find out why it is going click. Jack |
Post Number: 114 Registered: 10-2006 Posted From: 71.239.202.82
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 20, 2008 - 9:32 am: | |
There is an advertiser at the top of this page you might try. |
Post Number: 299 Registered: 2-2001 Posted From: 69.77.156.190
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 20, 2008 - 11:35 am: | |
I too have had a ticking relay (Eagle 15). It was just what Jack describes, a misconnected wire causing the self resetting breaker to cycle. Sounded like a turn signal flasher. By the way, those ads are selected by the content of the thread. |
FloridaCliff (Floridacracker)
Post Number: 387 Registered: 7-2004 Posted From: 24.27.228.155
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 22, 2008 - 1:10 pm: | |
When looking for relays check out ebay or surplus center www.surpluscenter.com/ .....Much cheaper than most anyone else... Cliff (Message edited by floridacracker on August 22, 2008) |
