Doug Ritter (Texrbama)
Registered Member Username: Texrbama
Post Number: 42 Registered: 3-2007 Posted From: 68.247.226.38
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, September 25, 2008 - 7:36 pm: | |
Question, my RPM gauge is off by 400 hundred rpm's. Where is the sending unit locatd on my 72 Eagle. 8v-71 , allison auto trannie. Thanks |
Post Number: 543 Registered: 8-2006 Posted From: 74.33.57.23
Rating:  Votes: 1 (Vote!) | Posted on Thursday, September 25, 2008 - 8:04 pm: | |
Doug, depends on what brand and type you have, some hook to the alternator,some hook to one of the drives on the engine with a sender generator or a magnetic sensor on the flywheel let us know what brand you have and maybe somebody can help.If you have the alternator type check the belts driving the alternator.I have a Dixson that is generator sensor driven off the engine and has dip switches on the back to adjust it with good luck (Message edited by luvrbus on September 25, 2008) |
Post Number: 1206 Registered: 10-2003 Posted From: 71.58.110.9
Rating:  Votes: 1 (Vote!) | Posted on Sunday, September 28, 2008 - 5:53 pm: | |
Make sure your tach doesn't have dip switches on the backside to set the accuracy. |
Post Number: 481 Registered: 10-2006 Posted From: 208.100.193.173
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, September 30, 2008 - 3:52 pm: | |
Last year for Xmas Da Bride gave me a Tach that operates with reflective tape. Will probably be at Jacks New Years party , again, and anyone wanting to use it to calibrate their tach is welcome to do so. FF |
Post Number: 275 Registered: 8-2004 Posted From: 72.12.39.78
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, September 30, 2008 - 5:43 pm: | |
Fred, can you give brand, model name, number etc? That sounds like a find! Thanks, BH |
Post Number: 545 Registered: 8-2006 Posted From: 74.33.57.23
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, September 30, 2008 - 6:13 pm: | |
BH, don't know what brand FF has but I have Redington model 9300 you can use tape with or without |
Post Number: 482 Registered: 10-2006 Posted From: 208.100.193.10
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, October 01, 2008 - 6:39 am: | |
Its in Fl, (on our boat) So you will have to wait a month . Will also post where it came from. FF |
Bob MacIsaac (Wildbob24)
Post Number: 21 Registered: 5-2007 Posted From: 70.220.63.246
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, October 01, 2008 - 10:09 am: | |
BH There are plenty of these hand held tachs on the eplace. Just search "digital tach" and a bunch of them will come up |
Post Number: 839 Registered: 12-2000 Posted From: 174.144.209.97
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, October 02, 2008 - 9:51 am: | |
I purchased one of these on Ebay. I don't remember the brand, but it has been used on everything from our bus to our lawnmower. Ours seems to work better if you are not in direct sunlight (I guess it has more trouble seeing the reflective tape in bright, direct sunlight). Jack (Message edited by JackConrad on October 02, 2008) (Message edited by JackConrad on October 02, 2008) |
