Gene Lewis (Genelewis)
Registered Member Username: Genelewis
Post Number: 83 Registered: 12-2000 Posted From: 76.5.169.230
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 26, 2008 - 12:14 am: | |
Have a 7 KW PowerTec Generator. Does anyone in bus land know right off what size pipe is required for the exhaust? I have mislaid (lost it somewhere) my paper work. Trying to eliminate the guess work. Thanks. gene |
Tom Christman (Tchristman)
Post Number: 21 Registered: 1-2006 Posted From: 66.218.33.156
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 26, 2008 - 1:32 am: | |
1.5", but using 2" would be easier. TomC |
Post Number: 837 Registered: 12-2000 Posted From: 70.0.51.33
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 26, 2008 - 8:46 am: | |
The fitting on the exhaust manifold on our 8 KW PowerTech (3 cylinder Kubota diesel engine) is 1 1/4" pipe thread. We installed a flex section, from PowerTech that had 1 1/4" pipe thread on each end. From this we went to 2" exhaust pipe under the bus to the muffler. Output from muffler is slighty smaller diameter. You can call PowerTech and ask for Jeff Jones. Jeff is very helpful and will answer any questions you might have. Jack (Message edited by JackConrad on September 26, 2008) |
Post Number: 22 Registered: 1-2006 Posted From: 66.218.33.156
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 26, 2008 - 10:36 am: | |
Gene- I have a trucker friend that had a Powertech 7.0 lay down compact on his truck with a Kubota 3 cylinder engine. When he sold his truck the gen had 23,000 hours on it. The generator had been overhauled twice, but the engine was not touched-very good units and looooong lasting. Good Luck, TomC |
