Post Number: 307 Registered: 6-2004 Posted From: 66.38.159.33
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 24, 2008 - 12:21 am: | |
I very recently acquired a couple of 1990 Prevost XL's equipped with 6V92's and 6 speeds. That will have to be the subject of another post!!!!! Both were non runners supposedly, but I got one running and it suffers from detonation. Da Book suggests a couple of causes: (a) oil picked in the air stream (b) low coolant temperature (not likely,since it does it with the temperature at 170*F (c) Faulty injectors. Which in the humble opinion of our Detroit experts would be the likely source? I have not yet removed the turbo etc. to have a look inside the blower if oil is bypassing the seal. Awaiting your opinions, Joe. |
Dan West (Utahclaimjumper)
Post Number: 130 Registered: 1-2005 Posted From: 208.66.38.60
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 24, 2008 - 8:43 am: | |
Joe, its supposed to detonate, thats what diesels do!!!!>>>Dan |
Grant Thiessen (Busshawg)
Post Number: 67 Registered: 10-2007 Posted From: 206.45.93.160
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 24, 2008 - 10:26 am: | |
I'm no expert but have had this issue that was caused by a faulty injector. Have fun |
Post Number: 344 Registered: 3-2007 Posted From: 71.55.230.210
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, November 24, 2008 - 9:07 pm: | |
Check the color of the smoke coming out the exhaust. Chanches are: at idle if you have faulty injector or injectors, first it will burn the eyes,white smoke, will kinda puff at you. I had one that had white smoke and when you mashed the gas it would spit black and white. Gray smoke is oil not fuel tho. Just a thought Gomer |
