Perry &Jeanne Blanch (Perryaw3)
Registered Member Username: Perryaw3
Post Number: 10 Registered: 5-2004 Posted From: 148.78.183.102
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 03, 2009 - 11:26 am: | |
Hmmm,one thing then another! Getting a heavy vibration (similar to driving on the rumble strips on sides of some interstates) upon accelleration. Smooths out fine at hwy speeds (50) Other than tranny fluid level any thoughts on what a guy can check ? (Engine idles fine, no rumble when coasting, only upon fuel application) Thanx! Perry |
bill chisholm (Billybandman)
Registered Member Username: Billybandman
Post Number: 144 Registered: 2-2001 Posted From: 76.115.17.91
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 03, 2009 - 11:42 am: | |
This is most likely bad u joints in the drive line. Not big deal at all. Pull the drive line and take to a driveline shop and make sure to install exactly as it was. |
Post Number: 677 Registered: 8-2006 Posted From: 207.231.75.253
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 03, 2009 - 11:49 am: | |
Worn U joints, or an injector not injecting. Please tell us if you have any unusual smoke while accelerating. As the convertor doesn't lock up until halfway thru second gear, (it feels like the second shift) do you have the vibes from a stop, or after lockup? Check the U joints before you drive it again. G |
Post Number: 610 Registered: 8-2006 Posted From: 75.164.110.50
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 03, 2009 - 12:25 pm: | |
Check the timing on your drive line and make sure the drive line is not installed backwards, my timing was off and I had the same problem. good luck |
Tom Yaegle (Tom_5c)
Registered Member Username: Tom_5c
Post Number: 28 Registered: 1-2008 Posted From: 96.233.252.187
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 03, 2009 - 12:27 pm: | |
Perry, Also check the flange bolts on the driveshaft. If you have flanges. Tom Y |
Post Number: 797 Registered: 11-2005 Posted From: 75.107.68.33
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 03, 2009 - 2:18 pm: | |
Had the same problem that turned out to be severely worn splines on the drive shaft slip joint. |
Post Number: 11 Registered: 5-2004 Posted From: 148.78.183.102
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, January 04, 2009 - 11:37 am: | |
The mystery continues...blocked up bus and had a look, all seems tight w/ u-joints & flanges. Dif fluid is correct level. George; no smoke, running fine. Not sure about exactly when vibes begin re:convertot locking up, but suspect it's after. (speeds in town) Was liking the u-joint theories, don't like thoughts of tranny problem ! p. |
Post Number: 798 Registered: 11-2005 Posted From: 75.107.68.33
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, January 04, 2009 - 2:14 pm: | |
Try driving very slow around a parking lot with no other noise around. I heard mine clicking when I did that at an RV park. U joints will do the same thing and is what I thought my problem was. At faster speeds it was masked by all the other noises. |
Post Number: 1276 Registered: 10-2003 Posted From: 71.58.110.9
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, January 04, 2009 - 6:19 pm: | |
If you've never done it before, it's time to remove the driveshaft and check out the joints and splines. If joints have any rust or wear in journals, just replace them. They are one of the cheapest items to replace considering their intended job. Might as well clean shaft thoroughly and paint so it looks pretty and gives you that warm feeling every time you look at it.Then lubricate on a regular interval per maint. book. |
larry currier (Larryc)
Post Number: 202 Registered: 2-2007 Posted From: 207.200.116.13
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 06, 2009 - 10:53 pm: | |
Got a lump on a tire? Loose wheels? Flat tire? motor mount bolts tight, bellhousing bolts tight? Drivelines are heavy but you can shake them if your strong, check for slop at the input and output side even if the ujoints are OK. |
Sammy (Sammy)
Registered Member Username: Sammy
Post Number: 88 Registered: 8-2005 Posted From: 68.237.215.35
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 10, 2009 - 10:42 am: | |
How is quality of Differential oil? Look for metal particles in oil to see if pinion bearings might be on the way out. |
Ednj (Ednj)
Post Number: 226 Registered: 3-2003 Posted From: 68.197.95.38
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 10, 2009 - 3:07 pm: | |
The guy below brought his car to the shop because of a small vibration. I know it's not your case, but look at these pictures. When questioned he said he ran over a Mattress a few weeks earlier? |
Post Number: 1165 Registered: 7-1997 Posted From: 24.239.13.27
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 10, 2009 - 9:03 pm: | |
Post Number: 1280 Registered: 10-2003 Posted From: 71.58.110.9
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 10, 2009 - 3:29 pm: | |
Only run over all FOAM mattresses! |
Post Number: 1452 Registered: 12-2000 Posted From: 76.68.121.244
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 10, 2009 - 10:32 pm: | |
OH DEAR!?!?!?!? That is simply an amazing set of photos. We could go out and run over 100 mattresses and I don't think we could duplicate this! Thanks for sharing! happy coaching! buswarrior |
Leland Bradley (Lee_bradley)
Registered Member Username: Lee_bradley
Post Number: 36 Registered: 11-2006 Posted From: 138.163.106.71
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 13, 2009 - 3:19 pm: | |
You can't check the u-joints with the driveline in place. Remove the driveline and check the u-joints for freedom of movement through their full range. U-joint generally sieze and cause the rearend or transmission to move up and down but under accelleration the rearend is hard against its stops and you feel the siezed u-joint as the rearend now moves up and down against the stops. |
Post Number: 380 Registered: 3-2007 Posted From: 71.55.230.210
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 13, 2009 - 7:51 pm: | |
Hummm I beleive that mattress must have been a KING SIZE judging from the looks of things. Quite interesting!! Does a torch,bolt cutters,hammer and chisle sound in order? |
Cullen Newsom (Cullennewsom)
Post Number: 20 Registered: 2-2009 Posted From: 98.201.161.214
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, March 06, 2009 - 10:15 am: | |
Did he say how many times he ran it over? |
Post Number: 542 Registered: 7-2006 Posted From: 75.211.63.169
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, March 06, 2009 - 8:26 pm: | |
Hmmmmmm...wonder whatever happened to Nellie?? RCB  |
