rod mercer (Rnkmercer)
Registered Member Username: Rnkmercer
Post Number: 1 Registered: 1-2009 Posted From: 72.139.67.158
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 03, 2009 - 3:53 pm: | |
I bought a new 12v snowmobile battery 4 years ago as a spare, never used it and until recently put good acid into it and it was still dead. I decided to charge it and after the 2nd day it slowly was taking a little charge but then I accidently turned the charger from a trickle charge to a 55amp boost charge for maybe 3 hrs. I am asking if this battery was done for to begin with or did I kill my battery. I still won't hold a charge even if the charger says it is at 100%. |
Post Number: 678 Registered: 8-2006 Posted From: 207.231.75.253
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 03, 2009 - 4:40 pm: | |
You're a MURDERER, (but I won't tell.) Actually it probably died about 2 years ago from neglect. Had you charged it every couple of months, for an hour or so, it would probably still be ok. Sorry, G |
Dan West (Utahclaimjumper)
Post Number: 149 Registered: 1-2005 Posted From: 208.66.38.115
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, January 05, 2009 - 2:10 pm: | |
Batteries HATE to be left in a dis-charged state for very long.>>>Dan |
Skip N (Skip)
Post Number: 31 Registered: 11-2006 Posted From: 161.7.93.216
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, January 05, 2009 - 3:50 pm: | |
Don't know if you still can but when I used to buy batteries as spares I would buy them dry and add the acid when I needed the battery. Probably To late for your current spare sometimes my equip batteries are juiceless after sitting all winter so I leave the charger on 40 amp for 8 to 10 hrs checking every now and then to make sure I haven't boiled it dry. Sometimes it works and sometimes I buy a new one. Skip |
ED Hackenbruch (Shadowman)
Post Number: 87 Registered: 11-2003 Posted From: 173.117.85.154
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, January 05, 2009 - 5:21 pm: | |
I was just looking at a battery website and it said that the monthly self discharge rate for a flooded battery is 13% and is 1-3% for gel and agm batteries. |
Post Number: 899 Registered: 11-2004 Posted From: 71.180.124.221
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 06, 2009 - 3:41 am: | |
I think Rod was saying he bought a DRY batt and didn't add electrolyte untill now - or maybe I'm mistaken? |
Post Number: 625 Registered: 10-2006 Posted From: 69.19.14.15
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 06, 2009 - 6:40 am: | |
IF it was dry , not a std wet bat with "extra" acid dumped in, all it needs is a deep cycle charger (Constant amps) and a day or two. These usually have timers on the face. FF |
Post Number: 150 Registered: 1-2005 Posted From: 208.66.38.115
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 06, 2009 - 11:11 am: | |
The average wet cell battery will loose 0ne to two percent of its charge per DAY under normal storage, it dosent take long to ruin a battery.>>>Dan |
