Randy Schlotthauer (Up8009) (152.163.188.227)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, September 02, 2002 - 8:41 am: | |
While brilliantly drilling holes in the floor of my MC9's front luggage bay, I managed to drill a hole in a fuel line (1" copper pipe)that I never knew was under the floor. I instantly had a diesel geyser. I made a temporary patch with rubber gasket and hose clamp. Other than draining the fuel system and replacing the pipe, any suggestions on a fix? Randy Schlotthauer |
degojo (198.81.26.174)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, September 02, 2002 - 11:19 am: | |
if you can cut the line, compression fittings will work |
