Bob McSeveney (Scout70)
Registered Member Username: Scout70
Post Number: 4 Registered: 8-2008 Posted From: 24.22.240.106
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 12, 2009 - 9:54 am: | |
I have a 73 MCI 5b challenger and would like to carry some type of portable tire inflator. Does anyone have a recommendation or suggestion on a quality reasonably priced inflator/compressor? Thanks. |
Post Number: 269 Registered: 10-2003 Posted From: 66.165.176.62
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 12, 2009 - 9:57 am: | |
I just put a quick connect fitting after the dump valve on my wet tank and I use bus air |
Dan West (Utahclaimjumper)
Post Number: 154 Registered: 1-2005 Posted From: 208.66.38.115
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 12, 2009 - 10:29 am: | |
As long as you have bus air you might as well use it, you can carry along a small portable inflatable tank to be portable.>>>Dan 4106-1261 |
Post Number: 203 Registered: 12-2000 Posted From: 24.164.20.23
Rating:  Votes: 1 (Vote!) | Posted on Thursday, February 12, 2009 - 11:06 am: | |
And while you're at it, get a locking tire chuck. Holding the chuck for 20 minutes while you inflate a tire can be maddening
(Message edited by lsilva on February 12, 2009) |
Roger Baughman (Roger)
Post Number: 68 Registered: 11-2006 Posted From: 75.3.207.153
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 12, 2009 - 5:40 pm: | |
What and where is the wet tank and dump value? |
Post Number: 270 Registered: 10-2003 Posted From: 66.165.176.62
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 12, 2009 - 5:50 pm: | |
The wet tank is the first tank after the air compressor and it usually has a valve on it to dump out water that accumulates in the tank. Don't know about your type of coach on my Flx the tank is on the drivers side rear just behind the rear tire |
David Lower (Dave_l)
Post Number: 126 Registered: 11-2007 Posted From: 67.58.201.10
Rating:  Votes: 1 (Vote!) | Posted on Thursday, February 12, 2009 - 6:57 pm: | |
Roger on my 1973 MC7 there is a tank below the drivers floor, you get access to it by a door in front of the drivers front wheel. open the door and it is above the opening. this is where I have a air line hooked up to inflate tires or run air tools. Dave L |
Post Number: 727 Registered: 8-2006 Posted From: 64.55.111.6
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 12, 2009 - 8:09 pm: | |
Take Dave's advice, as the air you get out of the aux tank will be much cleaner. G |
Post Number: 489 Registered: 7-2006 Posted From: 75.211.14.83
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 12, 2009 - 8:13 pm: | |
Tim...all my air tanks have "dumps" on them....are you sure yours do not? Might want to check if you haven't. And if they don't work right....they're cheap. FWIW RCB 1964 Crown Supercoach (HWC) |
Post Number: 490 Registered: 7-2006 Posted From: 75.211.14.83
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 12, 2009 - 8:15 pm: | |
Len...Amen to that...I didn't know about the locking chucks, but I'll be chasin' them down PDQ. Thanx for the "heads up"!!! RCB |
Post Number: 271 Registered: 10-2003 Posted From: 74.244.14.221
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 12, 2009 - 10:06 pm: | |
RC yes they do but I only have two tanks in tandem in the rear. The only thing on my Flx that is air other than the brakes are the wipers and horn |
Post Number: 493 Registered: 7-2006 Posted From: 75.211.14.83
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 12, 2009 - 10:11 pm: | |
Tim...nothing "up front"? RCB |
Kevin Black (Kblackav8or)
Registered Member Username: Kblackav8or
Post Number: 107 Registered: 8-2005 Posted From: 24.152.162.226
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, February 14, 2009 - 4:10 pm: | |
http://www.amazon.com/Snap-Ball-Foot-Chuck-Clip/dp/B001LMUN26/ref=sr_1_1?ie=UTF8&s=hi&qid= 1234645785&sr=8-1 |
Post Number: 204 Registered: 12-2000 Posted From: 24.164.20.23
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, February 14, 2009 - 6:21 pm: | |
Kevin, You'll find that ball foot chuck difficult to use on the inside duals. |
