Manual shift and clutch linkage remov... Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2009 » March 2009 » Manual shift and clutch linkage removal... « Previous Next »
Ben B. Wolff (Ben_mc7)
Username: Ben_mc7
Post Number: 25
Posted From: 24.73.7.114
Posted on Tuesday, March 24, 2009 - 10:35 am:
Has anyone here removed the manual transmission shift and clutch linkages from their MCI bus? If so, what is the process they went through?
I am changing from a manual to an automatic and would like to install a PVC tube through the linkage area to provide a tunnel to install additional wiring, auto shift cable and some plumbing.
Any assistance would be great. This is an MC7.
--Ben
941-725-0636, cell
wolffone2000@tampabay.rr.com
Username: Joemc7ab
Post Number: 336
Posted From: 66.38.159.33
Posted on Tuesday, March 24, 2009 - 4:21 pm:
Ben
Get out the gasax, otherwise known as cutting torch. If you wanted to remove the rods intact, I believe the engine cradle would have to be removed. You will likely go this route in anycase, seeing you are switching to an automatic.
Joe.
Larry Baird (Airhog)
Username: Airhog
Post Number: 151
Posted From: 12.144.222.163
Posted on Wednesday, March 25, 2009 - 10:35 pm:
I did mine, I cut the ends off then run the linkage rod for the 10 speed, air line and wires down the walkway. I covered the floor so it is level and at 6'3" I can still stand and not hit my head.
