Insulation & sound deadening Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2002 » October 2002 » Insulation & sound deadening « Previous Next »
john marbury (Jmarbury) (65.100.118.137)
Posted on Wednesday, October 02, 2002 - 9:07 am:
I'm about ready to cover the rear section of my 4905, I have sprayed thermal coat on the sheet metal. Any ideas on what other layers I should use to block Heat and deaden the engine noise.
John
John Biundo (Jbiundo) (67.112.121.112)
Posted on Wednesday, October 02, 2002 - 2:32 pm:
John,
A couple of sites you might check out are:
www.soundown.com (note: only 1 "d")
www.soundcoat.com
I've collected the URLs for checking into later, but haven't used (or really checked out) the products myself.
Let us know what you decide on.
Good luck,
john
David & Lorna Schinske (Davidschinske) (206.148.180.120)
Posted on Friday, October 11, 2002 - 2:17 pm:
Had a former appliance repair man tell us that we should remove the insulation from junked self-cleaning ovens and use. Supposed to have really high R-value. The stuff is usually free if you remove insulation yourself. We are thinking of doing this to whole bus if we can find enough.
Lorna
