Grant Thiessen (Busshawg)
Post Number: 125 Registered: 10-2007 Posted From: 206.45.93.160
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 30, 2009 - 3:39 pm: | |
I am going to start building a box to install my gen set in. I have the specs as to the size and I will be using fire retardent insulation. My question is has anyone used wood to line the inside of their box and what are the chances of it catching on fire. What is a good material to use to build a box. I don't have any room on the inside of the old A/C compartment so it will be a 3 sided compartment with the top insulated as well. I am istalling it where the A/C condesor was on my MC9 Thanks in advance |
Post Number: 586 Registered: 7-2006 Posted From: 75.208.204.199
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 30, 2009 - 8:54 pm: | |
Grant...I decided to use Hardy Board (sp) covered with fire retardant insulation... the kind used in automotive applications. Comes by the 5 foot roll, as I recall; about 36 inches wide or so. The edges are covered with Aluminum Channel....5 years later, no problems. "hooked" together in a couple of ways. Quiet, easy to build...easy to remove and re-install. Do it Ur way, as FF says... FWIW RCB (Message edited by chuckllb on March 30, 2009) |
Post Number: 1526 Registered: 12-2000 Posted From: 76.71.103.135
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 31, 2009 - 1:56 am: | |
Our fellow busnut Jim Shepherd sells fire detection, heat monitoring and suppression systems for generator compartments as well as the main engine room. http://www.rvsafetysystems.com/index.htm Support your local busnut! happy coaching! buswarrior |
Post Number: 732 Registered: 10-2006 Posted From: 69.19.14.43
Rating:  Votes: 1 (Vote!) | Posted on Tuesday, March 31, 2009 - 6:37 am: | |
http://www.soundown.com/S101.htm Ain't cheap but its probably the best in world. The 2 inch thick, 2lb lead sheet inside is grand!!! An OK place for " Bestitis". Your neighbors will think so , forever. FF |
William Garamella (Nh_wanderer)
Registered Member Username: Nh_wanderer
Post Number: 13 Registered: 11-2008 Posted From: 24.62.162.30
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 31, 2009 - 9:56 am: | |
I used SounDown's 2" 2# ft/sg fibreglass /lead sandwich material for the engine compartment (doghouse) on our 1983 forward control Wanderlodge. It really made a huge difference. I also put down their 2# ft/sq 1/2" thick rubber/foam sandwich sub floor and installed Dupont engineered flooring above. Very happy with results. My next project is the generator compartment. SounDown is recommending an adhesive damping material against the generator compartment surfaces and their 2# ft/sq composite material with decoupler over the damping sheet. As with the doghouse material, mechanical fasteners are required to keep this stuff in place. The fasteners are aluminum spikes with a perforated base about 2" square and these are mounted with structural epoxy. After these are mounted you press the sheeting over this (even the adhesive stuff), cut them to length, apply lock washer and then a finish cap. Gary Kissal is the rep I worked with there. Although this company caters to the high end Yacht crowed, he was genuinely interested in helping me with my low end bus project and the cost was not outrageous. I am only a satisfied customer and no other interest for making this endorsement. Here is Gary's e-mail address gkissal@soundown.com Bill |
Post Number: 126 Registered: 10-2007 Posted From: 206.45.93.160
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 31, 2009 - 11:00 am: | |
Thanks once again guys, sure make my job much easier. |
Jim Gibson (River_rat)
Registered Member Username: River_rat
Post Number: 4 Registered: 1-2009 Posted From: 75.95.96.192
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, April 10, 2009 - 10:06 pm: | |
I'm going to do the same thing soon. RCB - I beleive there are two kinds of hardy board, one is a concrete with fiber, the other is some kind of hard, but much lighter non-concrete. Which did you use? I am thinking the "mass" of the concrete board would deaden sound better. Jim |
Post Number: 609 Registered: 7-2006 Posted From: 70.212.142.12
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, April 11, 2009 - 11:14 am: | |
Jim...I used the only Hardy that I have seen. A dense cream colored product purchased at Lowes. 1/2 in thick...I think there is also a 3/8 inch board. Haven't seen a thicker one. The other that I am familiar with is Duroc.. a cement/fiberglass "crumbly" board...fine for underlayment, but IMHO not suitable for a high heat "box". FWIW RCB |
