Glenn Williams (Glenn)
Post Number: 211 Registered: 6-2006 Posted From: 216.163.56.194
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, April 26, 2009 - 11:15 pm: | |
I have never seen a post on this subject, but it is something every bus owner (especially newbies with older busses) should be prepared for! My MCI 7 has an aux fuel tank. Not long after I topped of my tanks for the first time, I developed a leak! My tank had corroded in several places in the bottom! So - now I'm leaking fuel, and I need to put 179 gallons of fuel somewhere! I burned up the phones looking for CLEAN 55 gal. drums that were used for something compatable with diesel. I found some, and didn't complain about paying a little for them either. Then I got busy with an el-cheapo electric fuel pump. That was memorial day of 08. Well, just under a year later, one of the hoses that connects my aux tank to the fuel lines that then attach to the main tank sprung a leak! Of COUSE I had just topped off the tank! Thank goodness I kept those barrels! A note on keeping empty barrels - keep them upside down to keep water from standing on the lid and perhaps getting into the barrel. Occasionally drain them - like an air compressor they will build up condensation. You don't want to mix that with your fuel! Don't ask me how I know! That story is also called "how I learned all there is to know about fuel filters". |
Post Number: 873 Registered: 11-2005 Posted From: 208.54.200.70
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, April 26, 2009 - 11:28 pm: | |
Glenn, If you really need to keep a big supply of diesel why not keep it in the barrels instead of the bus? |
Clint Hunter (Truthhunter)
Post Number: 151 Registered: 1-2009 Posted From: 24.129.235.190
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, April 27, 2009 - 12:55 am: | |
why I gladly have a bus load of barrels of fuel & I'd know just what to do with them. ... Not as sure how well this modern diesel keeps, you know technology these days, great effort to make most things last less. |
Ralph Peters (Ralph7)
Post Number: 3 Registered: 3-2004 Posted From: 66.59.120.99
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, April 27, 2009 - 9:10 am: | |
Now I know I will not sell my 3 truck fuel tanks each hold 120 gallons plus. One will fit in the bay and it holds 122, so 3oo total gallons, now that's big $$$$$. |
Post Number: 213 Registered: 6-2006 Posted From: 216.163.56.194
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, April 27, 2009 - 9:11 am: | |
Gus, My head is a little fuzzy this morning and maybe I didn't write the first post as well as I should, but I meant that the purpose for having the barrels is not to store fuel long term, but to have a place to put fuel if you need to do a fuel tank/system repair. On the other hand, whend diesel was 1.87 this spring, I kinda wish I had filled the bus AND the barrels! :-) Glenn |
Post Number: 647 Registered: 7-2006 Posted From: 75.211.137.82
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, April 27, 2009 - 10:44 pm: | |
"Now I know I will not sell my 3 truck fuel tanks each hold 120 gallons plus. One will fit in the bay and it holds 122, so 3oo total gallons, now that's big $$$$$." Also at the pump.......... RCB |
Post Number: 1280 Registered: 5-2001 Posted From: 65.74.69.200
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, April 28, 2009 - 9:49 pm: | |
Leaning barrels so that water drains off before reaching either bung keeps rainwater out, too. For what it's worth. Tom Caffrey PD4106-2576 Suncatcher Ketchikan, Alaska |
Post Number: 154 Registered: 1-2009 Posted From: 24.129.235.190
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, April 28, 2009 - 10:13 pm: | |
...was really hoping to inspire some fact sharing on modern diesel such as "ultra-low sulphur" & the perishability factor "chemical stability wise" and maybe even how it pertains to both MUI and electronic inject engines. |
