macgyver (91flyer)
Post Number: 361 Registered: 11-2004 Posted From: 74.193.225.134
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, April 27, 2009 - 4:55 am: | |
Hey guys... I went down to the local O'Reillies auto parts place looking for batteries and was let in on a little secret by one of the guys that I frequently buy parts from.... He said that *BRAND NEW* batteries, of any kind, regardless of the brand, type, voltage or size get SLASHED to only $20 if they sit on the shelf for too long. They call them "reconditioned" batteries... Basically, they're just batteries that sat long enough to naturally lose a couple of volts and stuck on a charger... That's it. There's nothing wrong with them... Most auto parts places are set up on a network that can check for these parts across all stores in the local area. Within a few seconds, they can tell you if there are any of these batteries available and where they are... And, in most cases, can have them delivered to your local store to pick up in one place by the next day or even a couple of hours! Just thought I'd pass on the info. Cheers! -Mac |
Post Number: 159 Registered: 9-2007 Posted From: 24.179.147.233
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, April 27, 2009 - 11:53 am: | |
Thanks for the info Mac, not only do I need batteries for my bus, but I need six new ones in my golf cart also, maybe I can save a bundle! |
Clint Hunter (Truthhunter)
Post Number: 152 Registered: 1-2009 Posted From: 24.129.232.82
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, April 27, 2009 - 3:17 pm: | |
...might be good candidates for desulphating at $20, which is likely why they failed the load test and ended up on the reconditioned shelf. Using them in a battery bank would need them to be reconditioned to very similar states or you would have imbalance charge problems & very short life with low performance. That is often the thing about secrets, they often tell less than the full truth. |
Post Number: 551 Registered: 1-2005 Posted From: 97.104.4.203
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, April 27, 2009 - 3:37 pm: | |
same is true for the INTERSTATE BATTERY DISTRIBUTOR - not the retailer - the DISTRBUTOR They also only have a 30 day warranty |
macgyver (91flyer)
Post Number: 362 Registered: 11-2004 Posted From: 74.193.225.134
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, April 27, 2009 - 4:23 pm: | |
Well... Ya can believe they're the rejects if ya like... But, personally... $20 or less for a usable battery that's just been recharged seems like a deal to me! ^.^ -Mac |
Post Number: 1421 Registered: 10-2003 Posted From: 71.58.110.9
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, April 27, 2009 - 4:49 pm: | |
If you want to go this route, you might want to look into Pulse chargers to desulfate them and chargers of this type are nice to use when coach is sitting for an extended time. Below is one of several companies that offer this equipment. http://www.pulsetech.net/ |
Post Number: 917 Registered: 11-2004 Posted From: 173.78.29.189
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, April 27, 2009 - 5:37 pm: | |
For a lot less $$$$$ this might work - I use it - some time you can find them on sale for less - FWIW http://www.batterymart.com/p-batteryminder-24v-1-2-4a-battery-charger.html |
Post Number: 311 Registered: 10-2004 Posted From: 173.77.212.104
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, April 27, 2009 - 9:03 pm: | |
Last year i picked upa Black and Decker smart charger a BC40. It has 4/10/20/40 amp charge rates, has switch for wet,gel,AGM,batteries; 110amp engine start,and a desulfate and alt.check function. the best part is you can carry this thing with 2 fingers, it cant weigh more than 4 pounds. The desulfate worked on a old motercycle battery. I got it at Walmart (gotta buy somthing for the overnite parking privlage). One of our best buys in awhile. |
Post Number: 1281 Registered: 5-2001 Posted From: 65.74.69.200
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, April 28, 2009 - 10:07 pm: | |
We use desulfators all the time. Tom Caffrey PD4106-2576 Sunctcher Ketchikan, Alaska |
Post Number: 654 Registered: 7-2006 Posted From: 75.211.121.125
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, April 28, 2009 - 10:25 pm: | |
Me, too....! RCB |
