Wayne Ellenburg (Wlnburg)
Registered Member Username: Wlnburg
Post Number: 48 Registered: 6-2008 Posted From: 128.158.1.163
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, May 07, 2009 - 4:21 pm: | |
I am about to redo the ceiling in my 01 Eagle. It was vinyl, had a few leaks, it was starting to come loose and want something different. I am leaning toward imitation stamped ceiling panels and wanted to hear other ideas before I make the investment. I am going to have to cover from the bottom of the radius on both sides. Thanks for your input. |
Bill Gerrie (Bill_gerrie)
Post Number: 260 Registered: 3-2006 Posted From: 216.198.139.38
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, May 07, 2009 - 4:50 pm: | |
Wayne I used the panels that are used in stick and staple units. They are paterned vynal on the face and waxed cardboard on the reverse. They are about 1/4" thick and come in 4'x8' sheets and will contour to the curved ceiling. You have to make up a seam hiding joint every 4' to make them look good. After 24 years they are still like new. A damp cloth once a year and they clean up. You will have to remove the interior cabinets to make the job easier to do or you are in for a lot of cutting. Bill |
Dan West (Utahclaimjumper)
Post Number: 177 Registered: 1-2005 Posted From: 208.66.38.60
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, May 07, 2009 - 6:38 pm: | |
I would want something to soak up noise.>>>Dan |
FloridaCliff (Floridacracker)
Post Number: 397 Registered: 7-2004 Posted From: 24.27.226.231
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, May 07, 2009 - 7:58 pm: | |
Wayne, Check out the pictures I posted of my ceiling. http://www.busconversions.com/bbs/index.php?topic=6976.0 |
Tom Christman (Tchristman)
Post Number: 81 Registered: 1-2006 Posted From: 66.218.33.156
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 08, 2009 - 11:22 am: | |
I have 2.25" of sprayed foam in both the roof and side walls-so further noise suppression was not an issue. My ceiling is 1/8" plywood covering that is painted semi-gloss white with 2" oak strips running lengthwise to hold it up. Simple, easily cleanable, can be removed if access is necessary, and easy on the eyes. Good Luck, TomC |
David B. Sweet (Sweets4104)
Registered Member Username: Sweets4104
Post Number: 23 Registered: 2-2007 Posted From: 75.51.79.90
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 10, 2009 - 5:01 pm: | |
We used Fibre Decor from Fibre Wall of Canada, we've had a minor problem with cracking where we used it a bit thicker than we should have, but its easy to fix. Its been up for two years and has some sound deadening and insulating qualities. Over all we are happy with it |
Post Number: 409 Registered: 8-2004 Posted From: 76.21.223.150
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 10, 2009 - 7:14 pm: | |
David, is "Fibre Decor" a 'paint-on' product? |
Post Number: 24 Registered: 2-2007 Posted From: 12.135.155.210
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 11, 2009 - 1:59 pm: | |
Fibre Decor is a papier mache type product it is mostly textile fibers with the adhesive mixed with it. Fibre Wall of Canada has a web site. They ship from I think Philadelphia to the U.S. You mix it with water per directions and take a small amount and place it on the surface you are going to cover and roll it out. They provide a roller cover with your first order. order. |
Post Number: 410 Registered: 8-2004 Posted From: 70.60.107.113
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 11, 2009 - 8:39 pm: | |
Thanks, David (there, eh?) |
Post Number: 25 Registered: 2-2007 Posted From: 75.51.79.90
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 11, 2009 - 9:19 pm: | |
Fact is a friend from Vancouver area put me on to it. Got one bag, tried it and was sold. We used it front to back or rather back to front in our '04 and are happy as if we had good sense. ;) |
