greg Herda (Mcibusnut)
Registered Member Username: Mcibusnut
Post Number: 1 Registered: 7-2007 Posted From: 96.54.9.143
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 12, 2009 - 12:47 pm: | |
I am just wondering where to place the support blocks when i remove the drive and tag tires that will support the weight so that i can install the air bag plates that separate the air beam from the air bags in my coach |
Bill Holstein (Billmoocow)
Post Number: 13 Registered: 5-2009 Posted From: 98.232.218.68
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 12, 2009 - 12:55 pm: | |
It shows it in da service manual. |
Post Number: 21 Registered: 5-2009 Posted From: 98.232.218.68
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 17, 2009 - 3:03 am: | |
You can order the service manual on ebay. It cost about 10 buck plus a couple of dollars shiping. It shows all jacking points of bus. Unfortunately it only shows mci9 but apparently they were same except cosmetic ?? |
Post Number: 22 Registered: 5-2009 Posted From: 98.232.218.68
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 17, 2009 - 3:12 am: | |
Actually, if i can make a copy i will send to you. Get a hold of me. |
Clint Hunter (Truthhunter)
Post Number: 184 Registered: 1-2009 Posted From: 24.129.235.190
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 18, 2009 - 7:06 pm: | |
... for MC 8 : block under the big frame down-leg , in rear of the drive axle (the vertical part that the axle position control rods attach to), lift bus & axle frame by placing your jack screws in the the vertical square down tubes located directly below the airbags, lower onto blocks. Keep your two jacks locked under the axle to manipulate the drive axle assembly you will be working on repair/rebuild. P.S. Block heavy shit safely or die dumbly ! |
