Post Number: 734 Registered: 7-2006 Posted From: 70.217.222.205
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, May 20, 2009 - 9:13 am: | |
The old fan has been removed (cat got in the way...)and now comes the fun. Suggestions appreciated!!!!! RCB |
Post Number: 472 Registered: 3-2007 Posted From: 71.55.197.237
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, May 20, 2009 - 10:00 pm: | |
RC, WHAT IS A Pancake Fan?? Never heerd of such a thang. Is that one when the stove is on and ya need to fan da fare ? Gomer |
Post Number: 736 Registered: 7-2006 Posted From: 70.217.222.205
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, May 20, 2009 - 10:50 pm: | |
....Gomer...UR at it, YET again!!!!! Pancake= amidships (CROWN, Peterbilt, and perhaps others) engine, laid on it's side with the Radiator on the driver side, not direct engine dirven, mounted on a cross frame member(not in line with the engine, but in the same plane, belt driven).....whew. Got it? Spent the ENTIRE day, cutting bolts and just attempting to get things ready to put in the fan( 24inch) Not real sure it can be done with just one person, but::::: Pray for me.... I'm in Las Cruces, NM if some one wants to have a learning experience.... Thanx for your...uh...remarks...(hey...got to keep things "lite", right?) RCB |
Post Number: 834 Registered: 8-2006 Posted From: 76.171.79.185
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, May 21, 2009 - 1:40 am: | |
No sensayuma at all! Where's John when we need him? Anyhow, good luck Chuck, and sorry about the cat. George |
Post Number: 473 Registered: 3-2007 Posted From: 71.55.197.237
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, May 21, 2009 - 8:55 am: | |
RC GOT IT!!! I had a friend that had an old flex that had something like that and it was a booger to grease let alone work on. Do you need a fan? I may know where I can find one. Just let me know. Thanks Thanks for the comment, I always felt that if you keep an open mind and spirit then you can think a lot better, I use the thought that God is in control and that if you trust in Him in ALL things you can accomplish anything you do. Gomer |
Post Number: 737 Registered: 7-2006 Posted From: 75.209.184.249
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, May 21, 2009 - 11:09 am: | |
Thanx, George...been wanting to rid myself of that wild critter for years...finally got her!.. and it only cost me $150 so for (new fan and some bolts)...and lots of WORK! Marvin without any question, this has been the absolute toughest job (for one man)that I have undertaken with this conversion, including re-siding with 10 foot sheets of steel and rebuilding the trunk door. I still haven't gotten the fan assembly remounted in the coach It is all put together and in position ready to be hoisted, but lifting it into place is going to be the trick. Today, Lord willing. (HE was sure testing my KOOL yesterday.) Thanx for the offer of a fan, but done a'ready. RCB |
Post Number: 742 Registered: 7-2006 Posted From: 75.211.84.156
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 22, 2009 - 11:18 am: | |
A question for the "pancake" owners..Doug, Frank, anyone else...listen up..Please?? How much clearance do you have,,,or know should be,,,in the fan enclosure, between the tip of the blade and the structure? I have the fan mounted and in place, but cannot seem to get the unit to the middle of the enclosure, which means the fan is touching the enclosure on one half. As I tighten the adjusting bolt, the fan assembly wants to move to a slight angle and prevents the alignment mentioned above. I have spent muchas hours on this and do not give up easily so am going to keep "trying". BTW, I have an access panel in the floor above the unit and can see that as the assembly is moved to center, it goes out of line at an angle. Is that clear as the Mississippi? If I could post a pic or two, I would, but haven't figured out just how one goes about showing detail on a 150x150...(I note others come across with huge pics in other threads)...guess it is just one more sign...maturity has for sure set in! Thanx for all input....careful here fellows...constructive, please!! RCB (Message edited by chuckllb on May 22, 2009) |
Post Number: 746 Registered: 7-2006 Posted From: 70.210.226.68
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, May 23, 2009 - 10:34 pm: | |
I ask again...see above post...pleeze???? Thanx, RCB |
Post Number: 480 Registered: 3-2007 Posted From: 71.55.197.237
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, May 23, 2009 - 11:17 pm: | |
RC!! could it be possible that the blade is too far up or down? Maybe just spacing it would solve the problem. When I put in replacement motors, the space of the fan usually is about a quarter of the way in the housings. Is this a squirell type of a fan blade? I have had to space the housing also to align the things up also. Also some units have the clamp that tightens up with 2 sides and you may tighten one or the other and align it that way.. Just a thought?? Gomer |
Jerry W Campbell (Jerry_w_campbell)
Registered Member Username: Jerry_w_campbell
Post Number: 14 Registered: 7-2005 Posted From: 208.51.51.25
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 24, 2009 - 10:50 am: | |
Hi RCB, I have a Detroit. As soon as I wake up I'll go out and check it out. Jerry |
Post Number: 749 Registered: 7-2006 Posted From: 70.212.163.176
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 24, 2009 - 12:29 pm: | |
Gomer...you just gave me an idea...the "housing" (bracket) that the shaft sits in has a bolt hole on each end. Only one (toward the inside) is used due, I presumed, to "room" for a long bolt, or perhaps for use in a right hand left hand situation.... Now, I wonder if I could use a short bolt to work in juxtaposition to the other...in other words to, perhaps work to push against the shaft from the opposite side, thus bringing it into alignment..don't know; guess I'll mull on it a day or two before going back at it. Your remark abotu the shape of the blade may be the exact cause. The former blade was flat in the center, with the blades being at the usual angle, The new blade has the same bolt pattern, but is thick (deep, like a bowl) where the blades start....but the entire unitI can't seem to get the whole assembly centered, east/west without the shaft angling....which causes the extremity of the blade to ride against the enclosure,....yatita, yatita, yatita, yakitty, yak.. Jerry, am grateful to you for checking it out. Wish I could enlarge the pic of your coach...if you have one, send it to me via regular email...I'd like to see it. Thanx to you both. RCB |
Post Number: 15 Registered: 7-2005 Posted From: 208.51.51.25
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 24, 2009 - 1:04 pm: | |
I will send you a photo of the fan from the back side. I don't know how yours mounts but mine is adjusted from side to side to tighten the belts. if the belts got too long the blades hit the side of the housing. There looks to be about an inch of space between the blades and the housing. Good luck Jerry http://www.crowncoach.bravehost.com |
Post Number: 750 Registered: 7-2006 Posted From: 70.210.187.242
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 24, 2009 - 6:58 pm: | |
Marvin...send me an email so that I can send a Pic to you...I can't seem to get it to go to you on outlook express from this end. Thanx RCB |
