Karl VanShellenbeck (Kvan)
Registered Member Username: Kvan
Post Number: 30 Registered: 7-2005 Posted From: 66.68.82.97
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, May 21, 2009 - 11:41 pm: | |
Hello all. My nephew used the coach a little while back and called about the water heater not working. Well I did not put much credence into it until it would not work for me. The problem is, I can't find it!! Anyone with an mc9 Marathon coach that can tell me where the water heater is. Maybe Roger? Thank Karl |
Post Number: 162 Registered: 10-2006 Posted From: 71.239.202.82
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 22, 2009 - 12:01 am: | |
if you have an aquahot that is what is making hot water otherwise it for sure be in the plumbing bay. I know the fellow with the very first Marathon Prevost conversion, a 1984. I'll bet you 2 have many similar accesories. |
Post Number: 699 Registered: 8-2006 Posted From: 74.33.63.151
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 22, 2009 - 12:04 am: | |
It is located behind the panel where the fresh water inlet is located on the drivers side good luck (Message edited by luvrbus on May 22, 2009) |
Roger Baughman (Roger)
Post Number: 105 Registered: 11-2006 Posted From: 71.136.13.235
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 22, 2009 - 3:36 am: | |
Karl, My water heater is next to the generator in the middle bay on the drivers side. Roger |
Post Number: 31 Registered: 7-2005 Posted From: 66.68.82.97
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 22, 2009 - 8:13 am: | |
Roger, is your generator mounted on the drivers side in your coach? |
Post Number: 33 Registered: 7-2005 Posted From: 66.68.82.97
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 22, 2009 - 11:01 pm: | |
Thanks Roger. I found the water heater, mine is also next to the gen set behind the galley cruise-air. The bad new is it leaks. Any recommendations on a replacement electric/heat exchanger water heater? |
