Kevin Sweeney (Sweeney153)
Registered Member Username: Sweeney153
Post Number: 6 Registered: 1-2008 Posted From: 216.6.130.4
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, June 03, 2009 - 9:20 pm: | |
I am looking into using Temp Coat http://www.temp-coat.com/ to insulate my 1979 Crown. I have not been able to find much info on this product. Has any one used this? I heard from one bus-nut who used it for part of his bus and liked it, any other input would be appreciated. Thanks Kevin |
Bruce (Bgs4104)
Registered Member Username: Bgs4104
Post Number: 15 Registered: 10-2006 Posted From: 99.129.164.147
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, June 04, 2009 - 12:29 am: | |
Try calling Gary Nickerson he had Coach Services in Paso Robles Ca. now is Enduro Trailers of Lake Havasu City Az. He has used it & sold it both. Shop #928-855-7888 6Am to 3pm Az. time. Bruce |
Post Number: 814 Registered: 10-2006 Posted From: 76.216.69.160
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, June 04, 2009 - 6:35 am: | |
I have used something similar , it was ceramic insulating beads mixed into the paint. Rolled on it looked fine , but the surface had the consistancy of 200 sand paper. This was a DIRT MAGNET of the first order!! The roof needed scrubbing almost monthly , and a 50th inch or so of insulation never seemed to help the 1 1/2 already there. Want to stay cool in the sunshine ? WHITE ON WHITE paint kept clean. FF |
Cullen Newsom (Cullennewsom)
Post Number: 54 Registered: 2-2009 Posted From: 98.201.161.214
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, June 04, 2009 - 10:30 am: | |
quote:This was a DIRT MAGNET of the first order!!
Any other roof coatings to stay away from? |
Post Number: 7 Registered: 1-2008 Posted From: 216.6.130.4
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, June 04, 2009 - 4:55 pm: | |
Temp Coat is not designed as paint"TEMP-COAT® IS NOT A PAINT TEMP-COAT® SHOULD BE TREATED AS AN INSULATION". You can put it on the out side but is designed tobe inside. They say on their web site that 15mil is equal to 19" of fiberglass bats. |
Post Number: 817 Registered: 10-2006 Posted From: 76.195.79.226
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, June 05, 2009 - 6:48 am: | |
"They say on their web site that 15mil is equal to 19" of fiberglass bats.' I have a really nice Bridge in Brooklyn you may be interested in purchasing. FF |
Post Number: 59 Registered: 2-2009 Posted From: 98.201.161.214
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, June 05, 2009 - 10:51 am: | |
Fiberglass bats?
Post Number: 8 Registered: 1-2008 Posted From: 216.6.130.4
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, June 05, 2009 - 12:02 pm: | |
I ment R19, but i agree it sounds too good to be true. I have spoken to two guys who use it commercially, One guy for a meat company and they use it to insulate their trucks and the other one uses it to insulate hi temp tanks and pipes like steam. they both say it works well |
Post Number: 1500 Registered: 10-2003 Posted From: 71.58.110.9
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, June 06, 2009 - 10:40 pm: | |
also, good quality house paint applied to the roof works well as far as durability goes. 1/50 inch can help, but is it worth the downside. Spending the money on a good inside foam job would be a much better investment. |
Post Number: 424 Registered: 8-2004 Posted From: 70.60.107.113
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, June 07, 2009 - 12:41 am: | |
Is this stuff meant to be "reflective"? I mean, can it be used inside a roof panel and get the same insulation value as sprayed on the outside? |
Craig Campbell (Craig_4104012)
Registered Member Username: Craig_4104012
Post Number: 56 Registered: 2-2009 Posted From: 174.147.225.44
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, June 07, 2009 - 9:48 am: | |
i am using a product called supertherm multiceramic. google it. ive tested it on a work van, it works GREAT. it does insulate like they say it does based on the comments of a few of the people that had rode in the van commenting on how great my ac or heat was based on the work season. "your van always feels comfortable as soon as you get in it" they say. 96 ford windstar white van, layer on the outside and indside r/19 value nenrgy penetration resistance. o and it finished smooth Fred, when can i come by and visit the open house on that bridge you have on the market? ;) does it come with a bridge owners association? if so the deal is out. i hate those people who feel like they have any business in my home and yard. if i want to collect 3 year old cars with blown motors then who are they to stop me? |
Post Number: 10 Registered: 1-2008 Posted From: 216.6.130.4
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, June 07, 2009 - 4:00 pm: | |
"Is this stuff meant to be "reflective"? I mean, can it be used inside a roof panel and get the same insulation value as sprayed on the outside?" According to their website it is an insulation product. For an RV or truck etc it is sprayed on the INSIDE. Not like the glass bead stuff that some put on their roof. They are sending me all the documentation along with a small can so I can test it my self. I plan on making up three plywood boxes, 1 insulated with fiberglass 19", foam 2" and temp coat 20mil. I will leave them in the sun for a day with remote temp probes in them then I will move them into the freezer and record my findings (Message edited by sweeney153 on June 07, 2009) |
Post Number: 427 Registered: 8-2004 Posted From: 70.60.107.113
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, June 07, 2009 - 6:57 pm: | |
Thank you, Kevin. I look forward to hearing the results of your tests. |
Post Number: 13 Registered: 1-2008 Posted From: 216.6.130.4
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, June 12, 2009 - 6:43 pm: | |
I did my testing. For some reason I couldn’t up load the lab results file here. They are on the MAK board under temp Coat. You can make of it what you like. I know some others are testing also and I hope they let s know their findings. http://www.busconversions.com/bbs/index.php?topic=12168.0 |
Post Number: 431 Registered: 8-2004 Posted From: 69.143.33.151
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, June 13, 2009 - 2:57 pm: | |
Kevin, when I read the thread on "MAK", it said "my results follow" but there was nothing else there. Am I doing something wrong? |
Post Number: 14 Registered: 1-2008 Posted From: 216.6.130.4
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, June 13, 2009 - 7:15 pm: | |
At the botom of the post there is a paperclip.that says "Insul comp.pdf (69.51 KB - downloaded 22 "times.)" Click on that |
