Exterior Door handle on 1987 MCI 102A3 Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2009 » July 2009 » Exterior Door handle on 1987 MCI 102A3 « Previous Next »
Roy Childs (Rchilds)
Username: Rchilds
Post Number: 8
Posted From: 142.161.144.205
Posted on Tuesday, June 30, 2009 - 3:46 pm:
I am interested in installing a door handle and lock system on a one piece MCI door. I would like to leave the air opener and closer system intact and add a handle to use when we are out of the coach. I am concerned that when the air door is closed, that the extra handle must remain unlocked as it would interfere with the air door opening when I activate the switch. I have tried to access the archives to determine what handle I need with no success. So there it is, does anyone know what handle I would need?
(Message edited by rchilds on June 30, 2009)
Chuck Newman (Chuck_newman)
Username: Chuck_newman
Post Number: 375
Posted From: 75.15.95.46
Posted on Tuesday, June 30, 2009 - 8:53 pm:
I have seen, I believe on this board, an article about using a truck door lock assembly. Also, Jack Conrad has a similar door lock on his bus.
"I would like to leave the air opener and closer system intact and add a handle to use when we are out of the coach." I don't know about your bus, but my 102 with pneumatic operated door is very stiff to manually open/close without air. My wife can't do it.
I like the pneumatic operation and plan to have air all the time for bags and air accessories. I saw a 102 owner with RF key fob to open/close the door remotely from outside the coach. You should have an emergency claw release to open the door in the front utility cabinet accessible from the outside. So you still need a dead bolt for security. My door has a built in handle.
Invest in driver, wiring, maintenance, and body manuals. They are pricey but necessary for this coach.
Cable (Fe2_o3)
Username: Fe2_o3
Post Number: 30
Posted From: 71.112.211.206
Posted on Tuesday, June 30, 2009 - 9:12 pm:
This might help ..Cable
http://users.cwnet.com/~thall/FAST%20FRED.htm
Ednj (Ednj)
Username: Ednj
Post Number: 253
Posted From: 68.197.94.196
Posted on Tuesday, June 30, 2009 - 10:23 pm:
Here's how I did mine. with pictures.
http://www.busconversions.com/bbs/index.php?topic=11374.0
Bruce (Bgs4104)
Username: Bgs4104
Post Number: 18
Posted From: 99.196.208.134
Posted on Wednesday, July 01, 2009 - 7:50 pm:
Roy: Does your 102 have a factory keyed lock on the door now?
If so use a power (electric door type) actuator to lock & unlock the factory locking unit this will keep the door shut when there is no air. You can disable the outside door switch at the same time when lock.
Chuck: Was the 102 with keyless fob Blue with red & blue ribbons on it? if so it's mine.
'89 102A3 N14 Cummins with 10 speed autoshift Bruce
(Message edited by bgs4104 on July 01, 2009)
Username: Rchilds
Post Number: 9
Posted From: 142.161.168.192
Posted on Wednesday, July 01, 2009 - 9:55 pm:
Bruce, I do not have the factory lock system currently, but, I believe I could get one from ABC. Your suggestion sounds like a good one. Are you talking about a power door lock from a car or truck that you could get at any auto wrecker?
Bruce (Bgs4104)
Username: Bgs4104
Post Number: 20
Posted on Wednesday, July 01, 2009 - 10:26 pm:
does yours have a slide lock lever on the inside of the door with a 4" plate around it? There is a bus scrap yard in Rantune, Kansas area Sam Caylar maybe some can find his # for you I am not near my files now.Some one said he die but some took it over & open.
They have junked MCIs and will remove used parts as need.
3J-32-94 LOCK ASSEMBLY
3R-29-61 KEY TUMBLER ASSEMBLY
FROM PARTS BOOK Bruce
Username: Rchilds
Post Number: 10
Posted on Wednesday, July 01, 2009 - 10:37 pm:
No slide lock lever. Mine is an 87. I'm looking in my book to see if I can find what you are referring to.
Bruce (Bgs4104)
Username: Bgs4104
Post Number: 21
Posted on Wednesday, July 01, 2009 - 11:37 pm:
Was in Rantune, Kansas area "Sam Caylar" he had ads in Bus Trader & BCM Bruce
FloridaCliff (Floridacracker)
Username: Floridacracker
Post Number: 411
Posted From: 67.8.98.138
Posted on Thursday, July 02, 2009 - 8:15 am:
I am in the process of doing mine.
I bought a new Peterbilt inside and keyed outside handles and a "Bear claw" mechanism.
You can use any handle with the "bear claw" manual or power
eBay item# 330338456545 is an example.
Order the installation kit with it and its a piece of cake.
Cliff
David Lower (Dave_l)
Username: Dave_l
Post Number: 178
Posted From: 67.58.201.132
Posted on Thursday, July 02, 2009 - 3:26 pm:
I just mounted a dead bolt in the door above the factory hand grab.
