Andrew Bowey (All2go)
Registered Member Username: All2go
Post Number: 17 Registered: 12-2006 Posted From: 74.202.25.11
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, July 01, 2009 - 4:12 pm: | |
I have two 13,500 btu Dometic Penguin rooftop air units but only one controller. Is there a way to splice them both into the one controller so that they would work in unison? The controller is so old that it is no longer available and the adapter kit is $300, way too expensive for me. The airs work great and so does the controller but on only one air at a time. A picture of the controller is attached here and if anyone has an extra one knocking around or knows where I could get one please let me know. It is so hot I really need a way to control both air units, I do not need zones, just both to work at once. (Message edited by all2go on July 02, 2009) (Message edited by all2go on July 02, 2009) |
Post Number: 938 Registered: 7-2006 Posted From: 74.162.82.56
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, July 02, 2009 - 2:04 am: | |
"Moor Pmet". Sounds Danish...? No wonder you're having a tough time finding one! |
Post Number: 548 Registered: 3-2007 Posted From: 71.53.155.14
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, July 02, 2009 - 11:04 am: | |
John!!! get a "mirrer" an look at her backwards and see watca git ? Oh could that be my eyes going bad? Gomer PS All have a safe holiday and remember what it is for and go to a TEA PARTY. |
Post Number: 18 Registered: 12-2006 Posted From: 70.223.70.219
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, July 02, 2009 - 12:20 pm: | |
Relief IS needed, does anyone else out there have any insight into Dometic rooftop air controllers? Please? (Message edited by all2go on July 02, 2009) |
Post Number: 549 Registered: 3-2007 Posted From: 71.53.155.14
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, July 02, 2009 - 12:48 pm: | |
I just found out that someone on line has rebuilt controllers. don't know who but said look up the part on-line??? gomer |
FloridaCliff (Floridacracker)
Post Number: 417 Registered: 7-2004 Posted From: 67.8.98.138
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, July 02, 2009 - 2:05 pm: | |
Andrew, You could go with a standard house type control! At your friendly Hardware or HD, Lowes....Probably under $30....not $300 A cheap one turns the A/C back on...ahhhhhh! Cliff (Message edited by floridacracker on July 02, 2009) |
Post Number: 941 Registered: 7-2006 Posted From: 74.162.78.46
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, July 02, 2009 - 11:27 pm: | |
Try the following places: http://greensboro.craigslist.org/rvs/1212024539.html http://www.aaarv.net/duorep.htm http://www.pplmotorhomes.com/parts/rv-air-conditioner-parts-1.htm http://www.heartlandowners.org/forum/showthread.php?p=74404 http://www.rvusa.com/forum/mbbs22/forums/thread-view.asp?tid=8682&posts=6 There's a ton, if you Google: duo therm air conditioner thermostat |
Post Number: 312 Registered: 2-2006 Posted From: 75.197.137.111
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, July 03, 2009 - 6:38 am: | |
Hi Andrew, Not that I can see because each board in the upper units, have power supplies that you would have to isolate or you will burn out both systems. A better way would be to scavange a selector switch, relays, and thermostat from an old window unit and adapt them to each upper unit. You would have to know how to remove the board and know which wire are for what to do so... Seems simple to an A/C guy.. Good Luck Nick- |
