gene reeves (Silverheart)
Registered Member Username: Silverheart
Post Number: 4 Registered: 5-2009 Posted From: 75.220.59.46
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, July 06, 2009 - 3:00 pm: | |
We are getting ready for a cross country run, leaving for Arizona in the Fall. I like carrying spare fluids for all the systems. The manual calls for 10 weight oil for the power steering. I have been having problems finding this. It seems that everything is multi weight these days. Is there a substitute, or a source for this oil. I have tried Napa, Tractor Supply and all the local auto parts stores. All that I have found is one place that offers a 5 gallon pail. And that seems a bit overkill. thanks gene |
John Lacey (Junkman42)
Post Number: 89 Registered: 3-2007 Posted From: 69.19.14.42
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, July 06, 2009 - 4:59 pm: | |
Try any farm store ask for hydraulic fluid. Pretty much all tractor and implement hydraulic fluid is 10 weight oil. You might also find that hydraulic jack oil is also 10 weight. You are right as it is far easier to find it in 5 gallon pails that in quarts. Try a kubota dealer or john deer dealer. regards, john |
Larry Higuera (Larryh)
Registered Member Username: Larryh
Post Number: 40 Registered: 6-2006 Posted From: 148.78.52.146
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, July 06, 2009 - 9:22 pm: | |
John, Try any dollar store they usually have power steering oil in quart containers. Larry |
Post Number: 1557 Registered: 10-2003 Posted From: 71.58.110.9
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, July 06, 2009 - 9:34 pm: | |
NAPA sells power steering fluid in quarts for cars also. You should be able to check the specs on it. It appears to be about 10 weight. |
