Tony Rian (Rianrts)
Registered Member Username: Rianrts
Post Number: 46 Registered: 1-2005 Posted From: 75.93.9.112
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, July 10, 2009 - 2:04 am: | |
I know a silly questions but on my 1979 rts transit my motor sits sideways meaning a rt or lt motor not sure but is my power steering pump and compressor different then the other motors that mount stright on? Thanks for the advice |
Post Number: 903 Registered: 8-2006 Posted From: 76.171.79.185
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, July 10, 2009 - 11:09 am: | |
No such thing as a silly question, just some silly answers! A serious answer though, is that you have a left hand engine. The compressor doesn't care which way its turned, and according to a GM owner, "only the crank turns the opposite diection." G |
Donn Reeves (Donnreeves)
Registered Member Username: Donnreeves
Post Number: 18 Registered: 3-2007 Posted From: 69.115.69.201
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, July 10, 2009 - 4:03 pm: | |
George is right an idler gear is switched to the right side for a right hand engine. the valve train always turns in the same direction. |
Don Evans (Doninwa)
Post Number: 220 Registered: 1-2007 Posted From: 208.81.157.90
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, July 10, 2009 - 11:53 pm: | |
What about the water pump and fuel pump? Seem to recall mention of needing the correct rotation pumps. T/F. Don 4107 |
