Benjamin Edge (Busnut1981)
Registered Member Username: Busnut1981
Post Number: 5 Registered: 10-2007 Posted From: 24.22.90.139
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, August 01, 2009 - 5:20 pm: | |
Has anyone ever used a 10-speed Fuller Roadranger transmission (e.g. RT-910, RT-11610) behind their 6V-92TA or 8V-71N powered MCI bus? |
Larry Baird (Airhog)
Registered Member Username: Airhog
Post Number: 168 Registered: 1-2001 Posted From: 75.208.201.5
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, August 02, 2009 - 12:47 am: | |
I just put a RTO and a 8V71T in my MC-7, nice combo but a little tall with 11R-24.5s |
David Guglielmetti (Daveg)
Post Number: 92 Registered: 2-2009 Posted From: 71.139.244.152
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, August 03, 2009 - 10:05 am: | |
Don't forget, there are different internal ratios on most of the 9/10 speeds. |
Tom Christman (Tchristman)
Post Number: 107 Registered: 1-2006 Posted From: 66.218.33.156
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 04, 2009 - 12:16 am: | |
9 or 10spd will work well-if you know how to shift it. I would use a 7spd overdrive-then you don't have to contend with the air powered splitters. The 7spd will have more then enough gear splits for bus use. Good Luck, TomC |
Post Number: 1593 Registered: 12-2000 Posted From: 98.192.173.82
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 04, 2009 - 2:25 am: | |
Ben - Why? |
Post Number: 982 Registered: 11-2005 Posted From: 208.54.200.120
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 04, 2009 - 10:47 pm: | |
I agree with Tom, 10 speeds are way overkill for a bus.. Six are probably plenty and seven are even better. |
Post Number: 169 Registered: 1-2001 Posted From: 63.77.108.210
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 05, 2009 - 12:42 am: | |
I went from a 4 to a 10 speed RTO-910 and I can not speak for the 6 or 7 speed but unless you have driven a 10 speed in a bus you know not what you speak of, best answers come from experience. I have a new 740 less torque converter for a good price for you non shifters. |
Post Number: 539 Registered: 5-2007 Posted From: 64.40.215.143
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 05, 2009 - 7:11 am: | |
Larry, How did you do the shifter? I really want to go that route someday. Currently have a 4 speed crash box and would like more gears. Paul (Message edited by dreamscape on August 05, 2009) |
Post Number: 170 Registered: 1-2001 Posted From: 63.77.108.210
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 05, 2009 - 10:53 am: | |
I used the complete setup out of a 70's Prevo, ran it down the floor walkway then covered it to make the floor flat. also ran the plastic air line and pyro wires. I cut a hole in the floor about a foot from the back on the left and ran the conection rod down to the trans. |
Post Number: 879 Registered: 7-2006 Posted From: 75.209.81.156
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 05, 2009 - 1:41 pm: | |
Gus...not sure I can agree on that. I use all 10 on most trips...at some time or another during the trip....9 and 10 most always, 8 and sometimes 7 in town, depending on traffic and grade, 5 and 4 from second, then mostly to 6.... First gear seldom used...second is usually start gear....on the flat, of course. The 10th gear is what gves us such good (10-12) fuel mileage, IMHO. FWIW RCB |
Kevin Black (Kblackav8or)
Registered Member Username: Kblackav8or
Post Number: 129 Registered: 8-2005 Posted From: 24.22.254.95
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 07, 2009 - 12:28 am: | |
A 13 speed actually has the most versatility and allows you to split the top gears without moving the shifter. Gives you that small step down when climbing a hill without moving the lever. Nothing says you have to hit all of them on the way up or down. You can start in 5th and only make about 4 or 5 lever moves to be in top gear but those lower gears and splits will come in handy at times along with reverse options. They are also very common. A 14613 would be both unbreakable and quiet in a coach. The 12513's tend to get noisy in overdrive after they are worn. |
Post Number: 1593 Registered: 10-2003 Posted From: 71.58.110.9
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 07, 2009 - 4:50 pm: | |
Go for the double overdrive...since the coach is light compared to a loaded truck, you won't miss the slight loss in low gears ratio.  |
Post Number: 95 Registered: 2-2009 Posted From: 70.135.57.202
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 07, 2009 - 7:54 pm: | |
FWIW, double over in 13s is pretty hard to find, was not that common in the older 13s. Some of the newer 18s have double over. Generally speaking, the overdrive ratio in a 9 or 10 is going to be lower numerically than a 13 speed. And the 9/10 is shorter than a 13. Forgive my ignorance here, but I thought that most buses were limited in the amount of room they have for longer transmissions...I'm coming from a truck background and am still learning my way around here. Okay, set me straight..... |
Post Number: 886 Registered: 7-2006 Posted From: 75.210.189.121
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 07, 2009 - 8:29 pm: | |
I think you did awready... ...us too> RCB |
Post Number: 96 Registered: 2-2009 Posted From: 70.135.57.202
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, August 08, 2009 - 11:18 am: | |
I guess I'm still not clear on what coaches have the physical room/length for a longer transmission, and what about the shift pattern? Forget about V drives. |
Post Number: 990 Registered: 11-2005 Posted From: 208.54.200.113
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, August 09, 2009 - 12:03 am: | |
RC, I guess my opinion is based on a few years driving an 18 wheeler which only had a 9 sp. It could have used 10 but didn't really need more than that. We always tried to avoid so much shifting so the idea of having 10 speeds in a bus is a bit too much. If you just love having all those speeds more power to you. I don't mind shifting but I do have my limits before it ceases to be fun!! With one very low gear for unusual situations, one gear close to top for hill climbing and the correct top gear for cruising that only leaves two or three more that are necessary for most buses. Even with a truck 9sp we seldom used first except when fully loaded. The only bad part was the wide spacing between 8-9, it slowed us too much on hills. I think a ten speed covers that hole. I have a 10 sp antique Dodge C900 tractor but have driven it very little, never loaded. |
Post Number: 171 Registered: 1-2001 Posted From: 71.95.226.178
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, August 09, 2009 - 4:41 am: | |
300 rpm splits and over 100 mph in 10th (OD) 11R24.5s..... Hot Dang was that a MC-7? (Message edited by airhog on August 09, 2009) |
Post Number: 888 Registered: 7-2006 Posted From: 75.208.81.25
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, August 09, 2009 - 9:05 am: | |
Hi, Gus...no I don't like all the shifting and have therefore...more or less...figured out what is necessary in most circumstances. Traffic situations, when one sometimes doesn't get the time to "think things thru" are the times when a three speed would be just fine, thank you I agree with you... but am glad to have the "redundancy" of a Fuller RR; fine transmission from my point of view! Have a good Lord's day. RCB |
Post Number: 1595 Registered: 10-2003 Posted From: 71.58.110.9
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, August 09, 2009 - 9:59 pm: | |
I changed an RT9509 to an overdrive and added a 13 speed overdrive rear section to make mine. Bought new top gears for front section, although I've read that the old gears can be swapped around in the front section to make it an overdrive, but may be noisy because of the different wear pattern created. Mine was nice and relatively quiet with the new gears. Stock RT00's are few and will require some looking. Also the shift pattern is reversed in top two gears when you make this change, unless you get the RTOX top cover, which uses a couple extra internal levers to accomplish it. You can now buy roadranger auto shift models that only require the clutch to start out. One model doesn't even need clutch activation. When they make an angle drive version of this, I'll have one.  |
Post Number: 100 Registered: 2-2009 Posted From: 71.139.244.152
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 20, 2009 - 10:21 am: | |
Does anyone want to contribute to which coaches can take a 9/10 speed based on physical length/space? |
Post Number: 411 Registered: 10-2003 Posted From: 74.244.14.221
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 20, 2009 - 7:30 pm: | |
I would be glad to measure the Flx. What is the length of a 9/10 speed. I haven't ruled this project out yet so I need to take the measurements anyways. |
Post Number: 1604 Registered: 10-2003 Posted From: 71.58.110.9
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, August 24, 2009 - 8:40 pm: | |
RT,RTO,11609 and 11610 transmissions are 28.9 inches. Length is installation dimension from face of clutch housing to front bottoming surface of companion flange or yoke. RT, RTO, RTOO 11613 is 32.1 inches. weight is about 600 lbs for 9 and 10 speeds; 660 for 13 speeds. These figures are for a #1 bell housing The weight of the housing needs to be added to total of either trans- alum- 23lbs, cast iron 76lbs. The 11 part of the number refers to torque capacity- 1150 lbs.-ft. Remember that this is rating for a vehicle hauling 80,000 lbs. Would handle more torque in our vehicles. |
