doug yes (Dougg)
Post Number: 94 Registered: 1-2007 Posted From: 174.131.122.226
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, August 24, 2009 - 9:53 pm: | |
The paint on this MCI is only 6 years old and it has lost all its gloss. Maybe it went through a truck wash with the acid spray on. Can it be polished back to a good shine or should I plan for a new paint job? |
David Guglielmetti (Daveg)
Post Number: 104 Registered: 2-2009 Posted From: 70.237.15.50
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, August 24, 2009 - 10:08 pm: | |
Can you find out who painted it and what brand/type of paint was used? |
Post Number: 1155 Registered: 12-2000 Posted From: 72.57.239.169
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 25, 2009 - 8:38 am: | |
I would try some red or white(finer) polishing compound, available at any auto parts store in the polsh/wax department, by hand in a small inconspicuous spot to see what happens (Message edited by JackConrad on August 25, 2009) |
Post Number: 755 Registered: 8-2006 Posted From: 74.33.54.207
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 25, 2009 - 10:55 am: | |
Perfect-it 3000 extra cut compound by 3M with a sponge buffer will do the job for cost about 40 bucks a qt |
Cullen Newsom (Cullennewsom)
Post Number: 136 Registered: 2-2009 Posted From: 98.200.242.221
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 18, 2009 - 1:08 pm: | |
1. Strip any wax. 2. Polish it with "Compound" - there are several grades, pick the one that you need, or try several steps using a finer grade (grit size) each time. On such a big job it will pay you to discover the one which gives the best result. 3. It might be cheaper by the gallon. 4. Wax it when you're done. |
