Darrell Black, DVM (Darrelldvm)
Registered Member Username: Darrelldvm
Post Number: 41 Registered: 6-2005 Posted From: 209.78.171.84
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 25, 2009 - 10:38 pm: | |
I don't know if this is the beat place to post this query, but you folks mostly come through with some help (except where to install my air dehyrdrator) I want to install head phones between my amplifyer and speakers in my in-dash 12V radio. The head unit has no amp. Radioshack used to have a unit with bypass switch and volume, but no more. Any suggestions? |
Wec4104 (Wec4104)
Registered Member Username: Wec4104
Post Number: 65 Registered: 7-2008 Posted From: 68.80.242.72
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 26, 2009 - 10:47 am: | |
Darrell - Can you clarify the purpose? Are the headphones to be used for music listening while driving? I believe that many states have laws against wearing headphones while driving (particularly if both ears are used.) If it is to be used while parked, or for CB radio use, and whether you want stereo or mono will impact the answers and recommendations. |
ED Hackenbruch (Shadowman)
Post Number: 152 Registered: 11-2003 Posted From: 70.193.65.159
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 26, 2009 - 2:23 pm: | |
I quit listening to the radio years ago...got tired of the same 10 songs, the commercials, and DJ's that have to shout at you and try too hard to be funny. Instead i listen to my wife, and the bus or the car that i am driving. Have heard things several that could have turned into big problems if i had not caught them when i did. Have driven as far as 1500 miles several times by myself and never turned the radio on......not even sure if it still works, and don't really care if it does. :>) |
clint hunter (Truthhunter)
Post Number: 424 Registered: 1-2009 Posted From: 24.129.232.219
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 26, 2009 - 3:47 pm: | |
Ditto edHACK, I perfer the sound of equipment being diligently monitored by all my senses. -The only time I ever have radio going is do drown out a passenger from bitching at me. Not like you can get any real news anymore from the 3 or 4 syndicates that own the whole shebang either. |
doug yes (Dougg)
Post Number: 95 Registered: 1-2007 Posted From: 174.131.122.226
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 26, 2009 - 9:26 pm: | |
The radio may have enough power to run a head set. You can buy a stereo jack that has a cut off switch built in: you plug in the headset and the speakers turn off. Available at radio shack. |
Post Number: 977 Registered: 7-2006 Posted From: 74.162.75.248
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 26, 2009 - 11:47 pm: | |
Yeah Darrell, ditto "Doug yes"! Rat Shack has the jack, and it's simple to wire in. You'd use the radio's volume control to set the headset volume. The downside of course, is the problem of keeping the headset's cord from getting tangled in the steering wheel. The plastic wheel and the plastic covering of the headset wire are like magnets. The damned wire will stick to the wheel at the most inopportune times. (like during quick turns) You can avoid that by slopping grease on the steering wheel. (Just kiddin'; don't try this at home) They make wireless headsets.... but for all the trouble it's worth to do all that, it would seem a whole lot easier to simply mount a decent speaker (two for stereo) at head height, or over your head at the driver's seat. You would get the same effect of a headset, without having to wear a headset. Good luck! |
Post Number: 931 Registered: 10-2006 Posted From: 76.200.209.136
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 27, 2009 - 6:19 am: | |
You might want to check with the local cops , I thought driving with a headset was illegal? FF |
Post Number: 903 Registered: 7-2006 Posted From: 70.212.227.235
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 27, 2009 - 10:43 pm: | |
Tis in some places....BTDT.. RCB |
Tom Christman (Tchristman)
Post Number: 112 Registered: 1-2006 Posted From: 66.218.33.156
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 28, 2009 - 10:30 am: | |
You won't get any sound between the head unit and the amplifier. Typically a headphone conversion would be added between the amplifier and the speakers so you could choose either speakers or headphones. I believe RS still makes it. Good Luck, TomC |
