Phil Smith (Phil_smith)
Registered Member Username: Phil_smith
Post Number: 37 Registered: 3-2006 Posted From: 24.116.71.31
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, September 07, 2009 - 11:10 am: | |
I've got an 8v-71N with N-65's and is 'A' timed. I installed a set of Jakes and they work pretty good, but my inquiring mind says-- "have I got the slave piston adjusted correctly for my 'A' timed engine?"... Da Book calls for .059 and that's how it's set. Wondering if improved performance would result from a different setting considering the 'A-timing' Phil |
Post Number: 1158 Registered: 12-2000 Posted From: 173.127.128.53
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, September 08, 2009 - 8:33 am: | |
I have heard of a few people that set them at .055. I do not know what timing was used on their engines. I have also heard of a few that had the their Jakes set at .063 and saw an improvement when they were re-set to .059. Jack |
Post Number: 38 Registered: 3-2006 Posted From: 24.116.71.31
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, September 08, 2009 - 8:44 am: | |
Hi Jack, My thinking was that with adv. timing, the setting would 'have more clearance' to compensate for the time it takes for the piston to travel a little farther. But I thought I'd ask the group for an opinion. I might experiment with different settings to see if I can detect a change in performance. I think I'll try .063 and see. Thanks Jack. |
Bill Gerrie (Bill_gerrie)
Post Number: 284 Registered: 3-2006 Posted From: 216.198.139.38
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, September 15, 2009 - 11:34 am: | |
Phil See if Don Fairchild will answer you. He told me to change my Jakes to .057 from .059 and the injectors to 1.484 from 1.54. I now have a great running engine and it sounds so smooth. I don't have "A" timing as I run DDEC IV on a 6V92TA which has a retarded timing for emmissions. Bill |
Post Number: 39 Registered: 3-2006 Posted From: 24.116.71.31
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, September 15, 2009 - 9:13 pm: | |
Thanks Bill, Great advice. I've read Don's posts and hold his opinion high. Don, are you out there? Phil |
Post Number: 42 Registered: 3-2006 Posted From: 24.116.71.31
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, September 20, 2009 - 1:11 pm: | |
Ok, I've decided that it's not going to make a difference. I'm leaving them set at .059 and be happy :-). After lengthy research on the web, I found no references to different timing effecting the Jakes. On to bigger fish ! Ok, where'd leave my pole ? |
